AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › DIY Constant Height › DIY Prismasonic Lens Bracket?
post #1 of 8
Anyone have any good ideas or pictures of a bracket I could make to mount my Prismasonic 1400 pass-through anamorphic lens to my projector/mount? I am moving from a shelf mounted projector and lens, to a celing mounted setup. BTW, I am setting this up for a Sony VW40 projector, with a Chief RPA-U mount.
post #2 of 8
I used a piece of mdf to make my ceiling mount base, and then made an extended version to include the lens. I did need to move the mount as the lens changes the central balance point. There are a few pics in my link below.
Gary
post #3 of 8
If you are looking for a simple design.
I copied Tor Arne lens mount. Just a few $
post #4 of 8
Gary
Gary,
Using a mdf/wood extended base is a good idea, and the change in balance is a good point. I use a lot of wood in my DIY projects, as I woodwork as a hobby. I am extending my projector mount down from the ceiling, so the wood base would have to be above the projector mount I'm thinking. Maybe like turning a shelf mount upside down and then attaching it to the extension pipe?
post #5 of 8
I like simple, and that looks pretty good. Are those extensions made out of metal?
post #6 of 8
Does this pic help?:
http://uk.geocities.com/g.lightfoot@...ope/mount4.jpg
I used a speaker bracket as my mount and just extended the pole.
Gary
post #7 of 8
Gary
Oh yeah, that picture helps a lot, and gives me another idea and option to consider. Thanks!
post #8 of 8
Yes they are. I walk in home depot and search for the smallest but strong enough piece of metal that would do the job without bending. Cost me lest than 5$. I should paint it but prefer to watch movie instead.
  Back to Forum: DIY Constant Height
