AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic PX80 Owners Thread
Panasonic PX80 Owners Thread - Page 193
post #5761 of 5765
Originally Posted by tydas View Post
Thanks so much! I'm currently using 6ft 28AWG High Speed HDMI® Cable w/Ferrite Cores from monoprice..i'll give your suggestion a try
Well, the thicker cable did not work...saw in another post that the HDMI® Active Equalizer Extender Repeater would fix this and it did!
post #5762 of 5765
Yeah, I had the same problem a couple of years ago. Luckily my g25 does not suffer from that problem. The px80 is in the basement with no PC attached!
post #5763 of 5765
I am curious if anyone knows if there is a option to reset the PX80 without a password for the reset option on the menu. For whatever odd reason the one I know I have set does not work and all of the dozens I have tried fail so I am at a loss. And I know for about 99.999% certain the passwords I have or would have used are not guessable by anyone in the house.
Need to reset because for some odd reason my OTA channel programming is being a bit flakey. Old channels are sticking even after supposedly resetting and scanning the list again. And some channels in particular if I mark them 'No' in the list and hit apply, they reset to Yes and end up back in the channel surfing list. Unfortunately these are channels at my old house which are far from reachable here.
post #5764 of 5765
According to a PX80 service manual:
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Disconnect the AC cord from wall outlet.
post #5765 of 5765
Lots of thanks on that one. Worked a treat!
Side note: While resetting I checked the hours and just recently broke the 10K mark. Nice milestone.
