AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic PZ80/PZ85 Owners Thread [No Price Talk]
Panasonic PZ80/PZ85 Owners Thread [No Price Talk] - Page 43
post #1261 of 12670
Well I finished my 100 hours with the break-in DVD, and I've been watching this TV for almost 6 days now. I'm very impressed. My last TV was a Toshiba 46H83 CRT rear projection. Obviously, this TV is so much more precise and crisp. In addition, the overscan was huge on my old TV causing me to miss much of the picture. Usually channel logos were cut off some. None of that anymore.
Colors are very bright and saturated....both on HD and SD. HD looks fantastic just like it should, but the SD is excellent too. On a couple of occasions I've had to question whether something was actually SD it looked so good.
The wide viewing angle is excellent. I can watch with ease from my computer at probably 140-150 degrees.
I haven't done any gaming yet as I'm waiting to get a few more hours on it first. I only have a Wii so I can't check out HD gaming
The TV itself is just about perfect IMO. The design is sleek, thin, stylish. I can see that the speaker shelf would look a bit odd if you are wall mounting. I saw one in BB hanging and the shelf just looked out of place. However, on the pedestal it just blends right in and I rather like how it looks. I really like how the sides of the TV taper and curve back slightly. Panasonic says this is supposed to make it seem thinner and I think it actually works.
I only have one complaint. I'm still seeing a slight greenish tint throughout the middle of the screen with reddish around the edges when there's a light color or white screen. This is being discussed further at http://www.avsforum.com/avs-vb/showt...9#post13467429
I have a tech coming tomorrow to look at it. We'll see what he has to say. It's really not a problem during normal viewing. I see it when I'm running the break-in DVD, when the TiVo displays a solid gray screen while changing channels etc, or if the programing has a large light color or white on the screen. I'm still not sure if it's just something that some sets have. I can see it in some degree and in different patterns on about every Panasonic plasma I looked at in the store. Still undecided as to whether I should exchange it. I should know more tomorrow.
Finally, I decided to give bias lighting a try. You can see some pics and a video of the setup at http://www.brothersontech.com/blog/n...lighting-cheap
Basically I'm just using a desk lamp and a 6500K compact fluorescent bulb. I'm sure it's not perfect but it looks great and only cost about $15.
In conclusion, I think this TV is simply excellent and a great TV for the price especially.
post #1262 of 12670
here's how to get the service manual if anyone is interested -
Originally Posted by kbuts34 View Post
http://www.copytechnet.com/forums/pa...nload-pdf.html
Click on "Untitled"
Then click on "Electronic Service Literature"
Enter Model # and search
i used it to get the th-50pz85u. not sure about the others. as usual.... be careful, load silver bullets, etc, etc....you know the drill by now.
post #1263 of 12670
Originally Posted by ElwayLite View Post
From Toms recommendations, Id say your bright, color and picture are all too high.
i had the 5084 and this set doesn have near the ir effects and i think the picture and blacks are better. i just had to do more tuning on this set.
post #1264 of 12670
Thanks for the link! I'm downloading it now.....
post #1265 of 12670
Originally Posted by bpmurr View Post
Currently I'm just using what Tom's posted and kind of like it. However, your not going to get LCD whites like this.
Mode: Cinema
Picture: 75
Brightness: 43
Color:35
Tint: -3
Color Temp: Warm
Sharpness: 0
Black Level: Light
All NR: off
Just curious, I'v tried searching through the thread for Tom's settings, are these the one's he recommended. I am currently using the break in DVD and want to begin gaming on it but want to break it in. Thanks
post #1266 of 12670
Can someone give a definitive answer to what sharpness setting doesn't mess with the signal at all? Since all the other settings on the 80s have 50 be the mid value, I would assume that 50 sharpness does nothing, 100 sharpness actually "sharpens" and 0 sharpness blurs things slightly? Or is 0 the "do nothing" setting and everything above applies a sharpening filter?
post #1267 of 12670
After about 50 hours of use, I have noticed that the color performance is getting better. Red and green are still oversaturated as before, but the decoding performance is greatly improved. I am now getting
R: +5.6%
G: + 3.8%
B: -8.2%
I have updated the recommended settings based on an HDMI, High-definition input. These are a little different (especially the Color setting) from my original post when I was using test patterns from a Standard Definition component input.
http://www.avsforum.com/avs-vb/showp...postcount=1067
post #1268 of 12670
Well after a full night of movies (Pitch Black and Transformers on HD-DVD) my set is showing tons of IR. I've ran my DVD for about 115 hours with all settings at 40 and I didn't see any problems right away but now it's VERY noticable. I'm going to run the DVD over night and see if it gets better with time.
post #1269 of 12670
R: +5.6%
G: + 3.8%
B: -8.2%
Thanks Tom!
Where did you leave Sharpness, 50 or 0?
post #1270 of 12670
Thanks Tom! Your setting really helps with the "rosy skin tone" and I am dying to tune up the Picture & Brightness after the break-in period.
One question: did you set the color temp to WARM under those numbers?
My eyes are definitely not as great or accurate as your equipment, but at those numbers (-2 hue, 41 color), the picture looks a little yellow-ish to me when temp is set to warm.
Thanks again!!
post #1271 of 12670
R: +5.6%
G: + 3.8%
B: -8.2%
This is great news.
Is it normal for decoding in TVs to get better like this? Does it normalize after x hours (any idea what this is?) and then stop changing or does it keep changing over the life of the TV (meaning you need to keep checking every 6 months or year)? thanks.
post #1272 of 12670
I have some more information about the 50PZ85U.
It turns out that the observation I made before about the red primary being so accurate in the Standard mode was only part of the story. What I saw was the result of 3 variables: Standard mode AND component input AND SD (480i/p) resolution. 720p and 1080i (component and HDMI) and 480p HDMI are essentially the same whether in Standard or Cinema. All show an oversaturated red primary, even with the Color control turned down to get reasonably good decoding. Odd.
Also, like a lot of modern digital displays, this one definitely performs the best with the HDMI input. With component inputing a 1080i signal, a 37.1MHz multiburst shows very rolled off luma resolution and non-existent chroma response. In comparison, the HDMI response looks crisp and clean. I also noticed significant color bleeding from test patterns on component inputs.
This is too bad. There is no technical reason why a display's component input can't offer perfect response with 1080i signals, but manufacturers just aren't making much effort.
I also finally checked the HD processing. Not perfect, but quite good. I set my Blu-ray player to output 1080i and used the Silicon Optics Blu-ray Benchmark disc for the test. I saw almost no jaggies and good detail. The Panny correctly deinterlaced 1080i video-based material, retaining the full resolution of the original source. However, it did NOT correctly deinterlace film-based material, discarding some of the available resolution. On the other hand, it did correctly apply 3/2 pulldown. The real-world implications of this are not serious, since Blu-ray stores the data in 1080p format on the disc anyway.
I checked the HD processing with actual program material using my favorite torture test Blu-ray disc, Mission Impossible III. The Vatican wall in chapter 7 showed just a hint of moire distortion in the lower right-hand corner and the staircase scene at the beginning of chapter 8 showed a small amount of line twitter. All in all, this was pretty good performance.
I am not particularly sensitive to motion judder inherent in the 3/2 processing necessary to display 24 fps film-based material in 1080p/60 format, so I did not test its 1080p/24 processing ability.
BTW, tests and tech talk aside, this plasma provides a VERY good image. The detail and depth are stunning and post-calibration the color is very convincing, though the oversaturated red primary gives skin tones a somewhat rosy appearance that was often, though not always, evident. Perhaps the most telling testimonial I can offer concerns a very high quality CRT that I love. I was amazed to find that it is now difficult to watch because the Panny plasma's detail and that "looking-through-a-window" experience is so much more compelling. This is true even for SD material where the CRT should have a natural advantage. The CRT looks dull and fuzzy in comparison. I have not seen any motion artifacts or problems with white field uniformity (perfect on my unit) that some others have complained of.
Settings for HDMI, High Definition
Mode: Cinema
Picture: 80
Brightness: 42
Color: 41
Hue: -2
As far as I can tell, the Sharpness control has no effect on the image when using the HDMI input.
Can I make the assumption that these settings and observations will also be true the 46PZ85U? Thanks in advance for all the information in this thread!
post #1273 of 12670
AM777, is this the same operating manual that can be downloaded from panasonic?
post #1274 of 12670
Nope, this is the service manual with info on the service menu, rgb cuts, drv, for greyscale calib, etc. Some Ppl in the 77u thread have been posting these settings along with their user settings, hope ppl here start too eventually.
see example - http://www.avsforum.com/avs-vb/showt...6#post13481066
post #1275 of 12670
am777, thank you for finding the service manual, it's a wealth of information.
post #1276 of 12670
No doubt the manual is a great find! My grandfather use to work on TVs back in the day so it's interesting for me to see the interworkings of this set in a format I can now understand.
post #1277 of 12670
sharpness does have an effect, its just very hard to notice a difference on a moving color picture. If you throw up a multi-burst pattern (series of vertical lines with gradually narrowing widths) and adjust sharpness up you will start to see white borders behind them and the very thin lines can start to shimmer if you turn sharpness up too high. Sharpness isn't really a setting, it's an enhancement in addition to you panels natural state. Sharpness of "0" on most (but not all) TVs is it's natural l look. On most TVs that I calibrate to ISF specs the TVs end up having their sharpness dropped from 75+ to between 0 and 10. Buying a DVD of HDTV test patterns will help anyone looking to dial in their TV greatly.
post #1278 of 12670
I did that. I don't see anything.
post #1279 of 12670
That's because your eyes are accustomed to seeing overly bluish displays.
post #1280 of 12670
Gosh, there's so much variability here that there's nothing I could say that would apply to TVs in general. I must say, though, that I am surprised at this turn of events. It looks like the green elements in this TV need some time to settle in.
post #1281 of 12670
Tom:
are you still going to use an external processor to correct the inaccurate colors of the PZ85?
-Robby
post #1282 of 12670
That's the truth, using your previous settings for the last week I can't go back to anything else. It's weird how your eyes adjust to the new colors and now everything else looks incorrect.
post #1283 of 12670
Interesting, any IR I get is usually gone in two minutes of watching something else.
post #1284 of 12670
Received my 42pz85u yesterday, and so far I have been following this thread as well as these forums for quite some time.
I finally decided to join the forums, and I have read almost everthing in this thread but one thing that was never clarified, was that does this set actually do dot by dot pixel mapping when in full type 2, and what should the color management setting be set to or what does it do.
I am having this set ISF calibrated by 1 of the 2 reps in the entire state of Wisconsin that work for BB. I was spoiled on my 32" Sharp Aquos GP1U as the definition with that kind of pixel pitch was just awesome.
What I mean to say is, I am noticing that the image is not as sharp as I am used to, it seems like close to 1080p but not quite, is there a way to have an ISF calibrator edit one of the modes to allow for dot by dot pixel mapping?
Lastly, I did not see any 3:2 pull down for 1080p60 sources, though I did notice my PS3 did accept the BD/DVD playback for 1080p24 without giving errors.
Any clarifications of these issues would be great, it is the 42" 85u if I did not already mention, which in general is amazing to the LCD as its colors in planet earth are amazing.
post #1285 of 12670
It says it enhances outdoor scenes, from what I can tell it mostly adjusts greens. The best thing I found to test this with was some golf in HD, with it on it made the grass look bluish and much less natural with my settings, with it off the green of the grass was perfect.
post #1286 of 12670
I am helping my brother purchase a new Plasma, viewing distance is 15ft.
My suggestion is the 58PE75U (720P) because you will not be able to discern the higher resolution in the 50PZ85U (1080P) at that distance, and really should be using a larger than 50" screen at 15ft.
Unfortunately, the TH-65PX600U (1080P) is too much of a price jump. Advice would be appreciated.
post #1287 of 12670
I just got my 50PZ85U yesterday. I got it all hooked and I am in the Break In process. I have turned off all the special picture adjusters (Color Management, etc). I turned on the Pixel Orbiter to 4. Turned the Picture, Brightness, etc to under 50 (I belive around 40).
The problem that I had been having is creating a copy of the Break In CD/DVD. I was having no luck with any of the tools. In the end I created 7 images, red, black, gray, light gray, dark gray, green and blue. They are all 1920 X 1080. I put them onto an SD card and plugged that into the back of the set. I then started a slide show, with a 10 second pause on each image. I can then leave this running for as long as I want. It just keeps repeating.
First, does anybody see any problems with this method? Second, I will be happy to share the images, if this is wanted.
post #1288 of 12670
I personally don't feel the break-in DVD is necessary, though opinions vary. You can run an HD channel with no logos (or the logos zoomed out) 24/7 until you hit the 100 hour mark, and keep the settings 50 or below. That's what I did and I've been playing COD4 an hour or two at a time with no IR. I ran about 150 hours on the TV before I turned it off the first time. This is what Panasonic recommends:
4. What is the "break-in" period and what should I do during the break-in period to minimize any risk of image retention? When your plasma TV is initially installed, the first 100 hours of use is known as the "break-in period." During this time, to minimize any risk of image retention, you should:
1. Make sure the plasma TV is in a viewing mode (aspect ratio) that completely fills the screen. The panel is shipped in this condition, in what is called the "Just" mode.
2. Turn down the Picture setting (in the Picture menu) to +0 [note: on the 85U 0=50].
3. Briefly engage the 4:3 mode and confirm the side bars are set to "Mid", or "Bright". This can be adjusted in the Set Up menu.
4. Always return the display mode that fills the screen (such as Just, Zoom, Full, or H-FILL).
5. Try not to view channels with stationary backgrounds or logos for extended periods of time.
6. Avoid extended display of static images (video games, computer images, DVD title screens, etc.).
LINK
post #1289 of 12670
All I can say is Tom's settings even though the picture is over 50 are fine during the break-in period. I haven't had any IR issues. Just the health bar in Ninja Gaiden being on the screen for like a minute or two after I was done playing the game. It was very faint and I had to go looking for it.
post #1290 of 12670
Agree with everything you said here about the set. As I've posted earlier and in the other thread I have the same greenish circle on light screens as you do. I know some people think we might be a little too picky but we see what we see. I can really see it with B&W material and on solid white screens.
I really want to see what the tech says you have coming out. I'll give mine a little more time and keep watching and see if it bugs me enough to try another set. I don't think this is normal because most people on AVS are more picky about the picture than your average person so if more sets had this problem I would think more people here would be seeing it maybe??
Keep us posted or PM me your results.
Jim
