AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic PZ80/PZ85 Owners Thread [No Price Talk]
Panasonic PZ80/PZ85 Owners Thread [No Price Talk] - Page 269
post #8041 of 12670
Originally Posted by jay5071 View Post
Hi
Need help please. I was watching TV this afternoon plasma Th-50pz80u and have only 15 hours break-inn pic 43 brightness 42, sharpness 43 everything looked great and then I had to go to a different room for about 25 minutes didn't realize the pic was frozen on the TV so i had the image on the TV for 23 minutes the minute i saw that i shut of the TV and waited 5 minutes before i turn on the TV every things looks OK i am watching football game i don't see any IR maybe i am not looking at the right place, How do i look for IR and did i ruined the TV permanently . I am worried sick , please reply thanks
You should be fine just watch some full screen HD content for a while.
post #8042 of 12670
Originally Posted by ampman337 View Post
I'm trying to be gentle with it, even after 3 weeks
For regular viewing (TV and DVD)
Cinema
Picture: +65
Brightness: +43
Color: +38
Tint: -3
Sharpness: 0
Color temp: Warm
Color mgmt: Off
x.v.Color: Off
When my son is on the Xbox I put it on the Game mode and have it toned down a bit more.
how many hours do you have around, and did you use the break in dvd? any sign of IR on the xbox?
post #8043 of 12670
How do you do a break in images and also where do you look for a IR
I am watching satellite and does not have HD at the moment so i am watching football on zoom full screen will that help thanks so much for reply
post #8044 of 12670
IR is an image that stays on the screen for a short time and then goes away, as to burn in that is permanent.....IR would be on your screen somewhere...if you cant see it, its not there
post #8045 of 12670
Probably around 250. I didn't use the DVD, I just made sure to watch a lot of full screen HD and I would occasionally change to zoom mode and H-Fill on 4:3 shows. No IR from the Xbox but I didn't hook it up till after 150 hrs.
post #8046 of 12670
If the images stayed on the TV for 23 minutes at low pic and low brightness . how will i know if there is a permanent burn or IR issue , to satisfy myself where will i look for burn issue or Ir is there a screen i can go to check
post #8047 of 12670
thank you for your reply, im trying to suck as as much info for my purchase as possible
post #8048 of 12670
Relax the TV is OK just watch your normal shows in zoom mode. No need for break in pics or DVD. Time would be better spent if you have a DVD player attached. Run a movie in zoom change your picture setting rewind movie play again, in this way you will get familiar with the menus and the setting. Rewind, replay, reset have fun you get to know your equipment and fulfill the break in period
post #8049 of 12670
actually the break in images are highly recommended here
post #8050 of 12670
What are the advantages over watching normal programming in zoom mode (facts)
post #8051 of 12670
Originally Posted by mantiz View Post
I found in audio options if you turn on the Bass boost option it causes a horrible sound anyone else notice this?
did you ever get a resolution on your bass boost problem? I'm experiencing the same thing.
post #8052 of 12670
You can run the break in images while you sleep, which decreases your break in time dramatically. My tv stayed on the first 4 days I bought it, playing nothing but images.
post #8053 of 12670
Doesn't say much in the manual, and yes many user have noticed the same thing. I believe most user ignore it by setting it off. Looks like a bad implementation of an old Boon Box feature.
post #8054 of 12670
Good for you, check your electric bill.
post #8055 of 12670
Ok smartass. You asked, and got an answer, guess you didnt like it. Instead of watching ZOOMED tv for 2 weeks, I broke the set in fast and then enjoyed it. Jerk.
post #8056 of 12670
This is a very personal call, you could build one to your own specs.
that is true, I personally am not very good with woodworking however I do have some family members that are. I would be worried about weight ratios though.
Say having the mount up to high and not having the base area heavy enough to keep it from tipping over.
Are there any good threads about building your own stands and mounts for a 50" Plasma?
post #8057 of 12670
Originally Posted by StuJac View Post
Those stands have weight limitations you should consider. I couldn't use one as the combined weight of my components would crash through the glass shelves. I spent weeks looking at stands. I ended up with something like this;
http://www.standsandmounts.com/index...OD&ProdID=5682
For my system I needed room for a center channel speaker along with 7 other components.
I also didn't use the doors for ventilation reasons.
the weight limits I have thought about and right now I don't have a receiver so i can't add that weight too it. I used too. anyway I do have a center channel and DVR box, wii, xbox, etc.... that is part of the reason I am looking towards wood stands. I just really like the wall mount style without the actuall mounting on the wall.
post #8058 of 12670
I like your humor but you lack good business practices and touchy as well.
post #8059 of 12670
Hey I'm basically running images 24/7 on my TV too for the first 4 days, I don't wanna know what my electric bill is gonna be....
post #8060 of 12670
it wont be much, only a dollar or 2 more. most flat tvs only use a couple a month at most
post #8061 of 12670
its ok to have this beast on for 4 days straight?
post #8062 of 12670
Seriously??? Then why is power consumption an issue at all when people debate Plasma vs LCD?
post #8063 of 12670
So we got a new tv, and the buzzing is now at an acceptable level where it doesnt bother us. The picture looks great. However, I am pretty sure it is clipping shadow detail, but the black levels look great. Should I worry about tackling this problem after break in? What do you have to adjust to not crush blacks? I know there is only so much you can do without pro calibration or using the service menu. Any suggestions?
post #8064 of 12670
I'm with Elway here. The man responded to your query in good faith and you have the temerity to condescend to him. Then when he defends himself you criticize his business practices and sensitivity level. If you have a differing opinion why can't you just say so? Speeding up the break-in period is an advantage and the usage of more power is not significant IMO.
You are certainly welcome to share and discuss your opinions on this forum but please try to be a little more respectful of others who share theirs.
post #8065 of 12670
I overreacted a tad (should have not used jerk), but as you can tell, it kinda pissed me off. Dunno what he means by "business practice". It also could be thats his way of humor, thats fine, if he'd have used some kinda smiley I woulda known and thought it was quite funny.
post #8066 of 12670
No difference in watching 100 hours continuously or 100 hours over 2 weeks. My goal was to get it broken in fast so there would be no zooming and use the slides. I actually did not watch it much those first 4 days, only a couple of hours here and there.
post #8067 of 12670
Check the calibration thread for this tv, we have a TON of good info for you.
post #8068 of 12670
I'd guess it's cost savings over time.
If I were to run my 42" for 8 hours a day at an average of 10cents/Kw Hour, it would be around $12 for the month.
post #8069 of 12670
try raising the brightness a notch or two.
post #8070 of 12670
No post
