AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Finally: Toshiba HL167 calibration post...better late than never!!
Finally: Toshiba HL167 calibration post...better late than never!! - Page 3
post #61 of 1150
I think I'm done!!!!!!!!!!!!
I tweaked the COLC settings and was able to pull the colors almost perfect. You have to use the Colormaster to get the colors perfect, service menu settings along don't get it right.
Try these settings and let me know what you think....i took some pics of Bourne Identity, 300, and Charlie and the Chocolate Factory...i'll see if they came out okay and post them if they did!.
Cuts New (Old)
R ECH (00H)
G EBH (F6H)
B 80H (00H)
Drives
R 76H (7BH)
G 70H (78H)
B 6BH (7EH)
COLC 40H
User Menu
Source HD-A30
Contrast 95
Backlight 35
Dynalight Off
Brightness 50
Color 53/Cable 26
Tint -9
Sharpness 30
Advanced Picture Settings
Dynamic Contrast Off
Static Gamma +3
Color Temp Medium
B Drive 0
G Drive -9
Noise Reduction
DNR Low
Mpeg Low
Colormaster On
R +24,+14,0
G -30,-20,0
B +8,+6,+5
Y +5,+20,-3
M -19,+23,+5
C -2,-12,0
post #62 of 1150
Cuts
R ECH (00H)
G EBH (F6H)
B 80H (00H)
Drives
R 76H (7BH)
G 70H (78H)
B 6BH (7EH)
COLC 40H
User Menu
Source HD-A30
Contrast 95
Backlight 35
Dynalight Off
Brightness 50
Color 53/Cable 26
Tint -9
Sharpness 30
Static Gamma +3
Color Temp Medium
B Drive 0
G Drive -9
Noise Reduction
DNR Low
Mpeg Low
Colormaster On
R +24,+14,0
G -30,-20,0
B +8,+6,+5
Y +5,+20,-3
M -19,+23,+5
C -2,-12,0
what hdtv model number is this calibration for?
post #63 of 1150
post #64 of 1150
I'm confused now. WHich of the colour setting should I choose?
post #65 of 1150
Yeah, I got I'm a little confused as well. It's hard to keep up these guys are rockin! Anyway, I'm still using Joe's settings from the 2nd page because I couldn't figure out which ones to use, in ( ) or not? Which are the new and the old?
post #66 of 1150
Cuts
R ECH (00H)
G EBH (F6H)
B 80H (00H)
Drives
R 76H (7BH)
G 70H (78H)
B 6BH (7EH)
COLC 40H
User Menu
Source HD-A30
Contrast 95
Backlight 35
Dynalight Off
Brightness 50
Color 53/Cable 26
Tint -9
Sharpness 30
Static Gamma +3
Color Temp Medium
B Drive 0
G Drive -9
Noise Reduction
DNR Low
Mpeg Low
Colormaster On
R +24,+14,0
G -30,-20,0
B +8,+6,+5
Y +5,+20,-3
M -19,+23,+5
C -2,-12,0
The settings seem perfect now great work!
post #67 of 1150
Wow !!! Yeah I agree this may be it. Looks good on my set as well. naturally I have tweaked a couple of user settings to my taste
I'll post my variances tomorrow !!!
Good job !!!
Kryspy
post #68 of 1150
I tried these new settings and for some reason it looks extremely washed out to me. Maybe I entered them wrong. For now I'm sticking with these settings. Cuts
R DCH (00H)
G B1H (F6H)
B BDH (00H)
Drives
R 75H (7BH)
G 6FH (78H)
B 6AH (7EH)
User Menu
HDMI 2 HD-A30
Contrast 92
Backlight 59
Dynalight Off
Brightness 46
Color 40
Tint -9
Sharpness 30
Dynamic Contrast Low
Static Gamma +3
Color Temp Medium
B Drive 0
G Drive -7
Noise Reduction
DNR off
Mpeg off
Colormaster Off
These seem to be working good for me. I'll guess I'll see what happens next. Thanks again for all your help.
post #69 of 1150
Agree here as well, I think I liked the previous settings a bit better, colors seemed bright and popped very well even in SD. Right when I changed the COLC I could see I was not going to like it, thanks for the settings though! I am sticking with similar to above along with Kryspy's settings and Joe's SM settings from before. I really like it.
post #70 of 1150
joe can you post the defualts for your tv, please
I'll post my defaults when I get home...they're on my laptop...
someone didn't read my first post about jotting down ALL default settings before making any changes......
it's all good...
or just use the settings posted here...i'm sure you will like!
post #71 of 1150
Default Service Menu Settings
RCUT 00H
GCUT F6H
BCUT 00H
RDRV 80H
GDRV 78H
BDRV 7EH
BRTC 78H
COLC AEH
UVTT 80H
CNTX 7FH
SHRC 00H
VBIS 01H
CC 01H
ID1 01H
GG 01H
PHDT 09H
OPT1 00H
OPT2 00H
OPT3 20H
OPT4 B7H
OPT5 01H
SETID B0H
MAGC 00H
VO1 5FH
V25 ADH
V50 DFH
V75 F9H
V100 FFH
VOLBS 00H
VOLST 00H
EVOL 00H
VOLX 64H
BASX 1AH
TREX 1AH
TONN 08H
BASC 02H
TREC 00H
EBAS 01H
ETRE 01H
WON2 11H
ALS 00H
ALOF OOH
VSTB OOH
VS3D OOH
VFCS OOH
VTBH OOH
VTBL OOH
VVDD F3H
WFCS 01H
WWSP 02H
WTBH 03H
WTBL 02H
VOLM 32H
post #72 of 1150
these are for the HL167 model specifically...all 3 sizes
post #73 of 1150
fixed them...sorry, the settings in the parenthesis are the default settings...
only difference you may have is that I used my HD-A30..YMMV...but put these settings in and let it sink in for awhile...then make changes if necessary...you need to let your eyes adjust....if you have to make a couple changes to your taste, that is understandable...these settings are almost perfect on my probe! i tend to go with physical numbers! but they also look great...color is tweaked lower to 26 for regular cable, but you are dealing with SD/HD/digital/analog sources, so you get what you pay for!
(waiting patiently for Feb. '09!!!!)
post #74 of 1150
Heres my changes:
Cable:
Color:56
Dynamic Contrast: High
on Blu-ray/HD-DVD Stuff
Dynamic Contrast: Off
Over The Air Antenna:
Dynamic Contrast: Low
That worked out for me restored the color and such.
without adjusting the image, it turns everyone pale.
Also make sure that on all your inputs the settings are the same because i noticed the input for my ps3 the colc was different
post #75 of 1150
Kryspy, I tried using your setup and close to 100% of the green have disappeared. Some reds, however, don't turn out as they're supposed to be. They turn out slightly purplish/pinkish like my signature below.
At least the TV is no longer puke inducing.
post #76 of 1150
Cuts New (Old)
R ECH (00H)
G EBH (F6H)
B 80H (00H)
Drives
R 76H (7BH)
G 70H (78H)
B 6BH (7EH)
COLC 40H
Colormaster On
R +24,+14,0
G -30,-20,0
B +8,+6,+5
Y +5,+20,-3
M -19,+23,+5
C -2,-12,0
To be used with the above:
User Menu
Source HD-A30
Contrast 95
Backlight 35
Dynalight Off
Brightness 50
Color 53/Cable 26
Tint -9
Sharpness 30
Static Gamma +3
Color Temp Medium
B Drive 0
G Drive -9
Noise Reduction
DNR Low
Mpeg Low
post #77 of 1150
Thanks..I'll put the settings in and sit on them for a while. I did think that maybe I just needed to give my eyes time to adjust. So the 26 is for regular cable not HD? Just wanted to clarify, that maybe where I went wrong.
post #78 of 1150
Originally Posted by Kryspy View Post
David Susillo,
Try mine which are based on JoeProcopio's previous settings. I have a build date of March 2007.
Service Menu:
Cuts
R DCH
G B1H
B 80H
Drives
R 70H
G 6FH
B 70H
User Menu:
Contrast 85
Backlight 40
Dynalight Off
Brightness 50
Color 40
Tint 0
Sharpness 25
Dynamic Contrast Medium
Static Gamma 0
Color Temp Low
B Drive -5
G Drive 0
Noise Reduction
DNR off
Mpeg off
Colormaster Off
Kryspy
Kryspy I noticed that the COLC setting drastically changes the color, what are yours set currently? For some reason and I seem to be with you on this, I seem to like the COOL color setting where as most of Joe's settings are based on a medium setting which to me makes my whites pinkish and people's faces very red...anyone have any other ideas to match up well with the COOL color setting? BTW I have a 47HL167 with a January 08 build date Cheers
post #79 of 1150
I have a 47HL167 as well. Joe's settings are extremely warm for my tastes. I went back to Kryspy's settings and they are alot better.
I tried Joe's settings with the temp set to cool, but it looked washed out. Medium was too warm.
post #80 of 1150
the 26 is a compromise between HD and SD content over my Cablevision...used some SciFi SD, Deal or no Deal HD(highly saturated), and CSI Miami HD to get a good number to where I don't feel the need to change...but I have found that is subjective to your input...
post #81 of 1150
that's weird...it should be the same for all inputs...since they are service menu settings and not user/input settings...but definitely check that out!
I'm just glad that these settings helped some people see the potential of the set..no more of this Green Push nonsense...from Day 1, I knew the set could be tweaked correctly, I was just waiting for my probe! I was NOT going to spend almost half of what I paid for the set to get a pro calibration.
Good viewing to all and enjoy a great set for a great price!
post #82 of 1150
Pillowhead,
I am currently using JoeProcopio's newest set-up.
On my previous set-up my COLC setting was 76H. Currently I am using 60H with JoeProcopio's settings.
Kryspy
post #83 of 1150
Thanks, as for the difference between all the settings, I'm happy that I actually have a choice now! And not being stuck with the green screen. After changing the settings back and forth and trying new things I can tell you that I appreciate all the work you guys have done. It must be a pain in the a$$ after a while.
post #84 of 1150
Pillowhead,
Kryspy
Kryspy,
Are you also using the colormaster settings and everything else included? I'd like to know if you have made any adjustments? That way I could give those a shot and see the diffference between the two.
post #85 of 1150
just ask my wife, lol!
post #86 of 1150
for those interested...I will post the calibration file when I get home. You need to download HFCR for Windows to read it, sorry you Mac guys, it's not available for you yet. It shows grayscale tracking, CIE chart, RGB Levels etc...for you techies....
post #87 of 1150
Oh man I bet! I keep trying out these new settings and asking mine what she thinks, now I only get a blank stare!
post #88 of 1150
Good job !!!
Kryspy
You going to post your settings up soon just reminding you if you forgot.
post #89 of 1150
Hey Kryspy,
Yeah that would be great if you could post your settings for us "COOL" color guys
post #90 of 1150
I have the Toshiba 46RF350U set and have followed Joe's and Kryspys settings and am very happy with the picture of my set now, I believe I had green push? The background scenes/night scenes looked green/blue certain clothes,never people though. I never noticed at first, but after having my set for a few months now, blues and greens/turquoise all of a sudden stood out like a sore thumb,couldn't take my eyes off it. Not sure why, it seemed to show up all of a sudden. Was it green push, Anyone?
Either way, I was surprised when I could get in the service menu ( info from you guys)and do some adjusting, I am still playing with it a bit but your guys settings seem to make a huge difference with this set as well, I figured they must be similar??
Anyway thanks for all the effort you are doing more patience than I have!! Jim
