Originally Posted by drjmoo1
@ kdh05: I soldered on a 1uf tantalum cap and sure enough it worked! Then after about 10 minutes of watching it died again with a 4 blink error. Now I am back but I think worse then I started because 4 blinks seem a lot leas common then 10.
Any ideas?
So after I posted this I plugged it back in and I got a 10 blink code again. This leads me to believe it was the same cap again.
Can you tell me what direction I should have installed the cap in for proper polarity?
Any ideas?
Negative should be up towards the edge of the module. Positive down towards the center of the module (towards the P board).
As you know, it is a soldering challenge. Make sure you have good solder joints, and no shorts/bridges.
Hope you got it!
