Originally Posted by chrisng
I have the two blink problem with my 50PZ800 and am attempting to replace the 1uf capacitor on MC201 and MC301 as identified by kdh05 earlier in this thread. I was hoping you could tell me if a) the capacitor has polarity (i assume yes) b) how the polarity is orientated and c) what is the package size of a cap that can fit (so I can order one online)
I was intending to order a 1uf 25v tantalum (is 25v sufficient voltage as dtvjho used a 50v) which has a band to indicate polarity but the existing cap on MC201 is not marked. If we could use post #1111 as a reference can somebody help me with which side has what polarity?
In going back through this thread, I found this post which might be helpful:
Originally Posted by kdh05
@ kdh05: I soldered on a 1uf tantalum cap and sure enough it worked! Can you tell me what direction I should have installed the cap in for proper polarity?
Negative should be up towards the edge of the module. Positive down towards the center of the module (towards the P board).
As you know, it is a soldering challenge. Make sure you have good solder joints, and no shorts/bridges.
