Originally Posted by ehsenshaikh
I have a 42 inch plasma TV which I purchased in 2008. Two weeks ago it suddenly shut down and its power LED blinks 6 times and then completely turns off. If I start to switch it again it does the same thing.
I sent it in to Panasonic and they tested it for 2 days and said it worked fine. They returned it and it had been working fine till today when I tried connecting it to my Laptop through HDMI. Did the same six flashes, I unplugged it for around 15 min. Plugged it back in and its working fine again.
What could be causing this malfunction. If it helps, I have the TV connected to a QED Power conditioner through a MGE UPS. The HDMI cables that I use are QED gold plated edition.
Thank You.
My setup is as follows:
PS3, Denon DVD player, WDTV 1st generation (connected to a 1TB HDD) all three going into a Oppo HDMI switcher which relays the signal through another HDMI cable to my Denon AVR and from there to my Plasma (as my plasma only has one HDMI port). So, whenever I use any of these 3 devices sound is relayed through my amplifier to my KEF towers.
In addition I have a Coship digital set top box connected to my Plasma through normal av cables.
For the record, around 2 months ago my WDTV started playing up. It would randomly restart itself during a movie playing. I googled and found that I'll have to replace the unit. Just thought I'd mention it if someone sees a connection between the two or not.
Thank you.
Thank You.
Thank you.
Regardless of what the blink code is meant to mean, your purchase date suggests that you have a PZ/PX series model, and I very, very strongly suspect that your symptoms are being caused by the usual failing caps on the MC201/301 modules on the power supply board, as I have described in post #1447 and a number of earlier posts. Regardless of whether or not these two little capacitors are the only problem, they NEED to be replaced before any valid diagnosis can be made of other/remaining faults.
