Originally Posted by
Paul_in_MI
Just wanted to update you all. The technician was out today and the 11 blinks represented a fan issue. He took the back cover off and one of the wires to the fan was cut when the wall bracket was mounted to the TV. It appears that the wire was between the back panel/case and adjacent to the hole that the screw to the bracket goes into. Technician said this is a common issue and easy fix.
When I resetup my Plasma after 1.5 years of storage, it did not work. After 10 seconds, the power shuts-off and the red power pight blinks 11 times. As indicated by the Concierge service, it is a mechanism that shuts the entire system is there is a low voltage, over-temperature and other precautions that would make the TV damage itself.
I opened the back panel and powered the TV and viola, one of the fans are not turning! Probably because during transport, the connectors got loose.
Anyway, for 11-blinking red lights, its good to open the back (being very careful not to touch anything) and check if there are burn marks, bulging capacitors, cracked diodes, melted wires and other signs that are not common -- like none rotating fans.
