All boxes have these features............................... Unique DTVPal features
• ATSC tuner .................................................... • Program search
• RF out port .................................................... • Event Timer (Scheduled to occur daily, weekly or Mon-Fri)
• Digital close caption ........................................ • Uses customer’s zip code to confirm the time zone for EPG
• IR sensor ....................................................... • Software Update enabled - according to solidsignal
• Parental control .............................................. • TVGuide EPG
• Auto Power down / Auto Scan ........................... • Advertisements on EPG
• NTSC modulated out channel (3 or 4) selectable
• Electronic Program Guide
• Composite Video Out / RF Out
We already know it will have:
Analog PassThrough, 7-day EPG, External Power Supply, Event Timers
I don't think they will call it VCR Timers as it has no IR Blaster.
I did not know it would have
software update enabled.
It must update over the air as it does not have a upgrade port like the Tivax or Artec does for example.
Some boxes do have a Manual Channel feature but it's not documented like the Sansonic
Originally Posted by
MikeBiker
You can use the signal strength meter to manually go to a physical channel.
