Originally Posted by bkb99
I haven't had any problems with the DTV-Pal. I'm 20 miles outside of Little Rock.
After reading about the timer issues, I setup 4 daily timers nearly 2 weeks ago. They are all still there and all still the correct times and channels.
I turn off the PAL after every time we use it.
I've never seen an EPG download screen. Mine only seems to load the EPG for the channel I'm on. If I go straight to the "Guide", I get "No Information available" for all channels except the one it is on...until I've clicked through all the channels.
I have an F100 box.
I have an F100 box.
No Problems
What do you call the situation you are describing?
As I understand it, the EPG is supposed to to be an Extended Program Guide.
When you go to the Guide, it should display Program Information for all the stations, since it was off, and would have been able to do scans.
The bad news is that it sounds like your EPG is broken.
The good news is that your timers work, but that may be because your EPG is broken.
I guess that is the DTVpal world.
