Originally Posted by dagger666
Next time someone on here talks to dish about the DTVPAL/TR40 ask them who was the genius that figured it was fine to make the timers turn on the box but not off after the event is over. Why they felt it was better to let the box remain on for a minimum of 4 hours after a timer event then just let the box turn itself off.
Not sure it's 4 hours AFTER the timer event is finished. It might be 4 hours from activity (timer fired) until timer duration is over. So a 12 noon timer that goes until 5 pm might power down a short time after that...
They might have designed the DTVPAL timers NOT to power down to allow for "soft" padding of a program.
How many programs on TV today have strange run times that may run long and not always conform to the official guide. Sports might be an easy example. It could also allow for Marathon Recording... While a CECB can't get Sci-Fi channel there is a a Lost Marathon on Mondays from 7-11ET. If a broadcast channel had the same thing that would be all 5 timers. Since the DTVPAL doesn't power down after a Timer you could setup a Weekly timer at 7ET and a standby shutdown of 5 hours. That would leave you with 4 timers for other events. If there are other programs (local news?) on the channel after the Marathon you could make other adjustments and have the recorder record those programs too.
