Originally Posted by ucmerick
Don't confuse digital signal transmission with data stream decoding (specific conversion and/or use). The reception of the (analog) TVGOS data stream is path independent to the (analog) TVGOS device. Whether the required data stream was broadcast in a digital or analog transmission is irrelevant. Only that an (analog) device receives the (analog) data stream. The data stream means nothing to the Pal - it does not even "see" it in the transmission. It just converts the digital broadcast (transmission) signal which contains it to analog and indirectly converts it also since it is one of several data streams (like SAP, CC etc.) contained in the transmission signal. It does not specifically decode or convert the analog TVGOS (or the others) directly and it is not even aware of it (them) since it is not an end user (decoder) of the particular data stream(s).
So, if it just converts the signal indirectly, like SAP or CC, why then doesn't every other CECB convert the TVGOS signal to something your Panny can use? I think you are incorrect, sir.
