I'm designing, more or less, speaker covers and not really a full false wall. I have a few questions.
Should I have the entire stage covered with carpet first and then build the framing and fabric covered panels on top of it? Should I build the framing and fabric covered panels and then have the stage covered with carpet up to the framing and panels?
Do you think it's better to make custom AT panels to fit the framing or is it better to make the framing fit standard fabric stretcher panels?
Thanks in advance!
Dave
Thanks in advance!
Dave
. I tried to leave some wiggle room, but I did not leave enough. It was not that big of a deal though, I just removed the staples from the bottom of the 2 lower side panels and pulled the fabric back a little. I then ran that edge over the table saw and cut about 1/2" off the bottom. Then I reattached the fabric again. Took about 45 minutes to fix. The large panel in the middle did not require any adjustment because I could shift it up a little since the top lies behind the screen.
