Not exactly sure where to post this, so I hope this is the right spot...
OK. I'm about to buy an Olevia 23" TV (I know it's small, but it's all I can afford
) The set says HD-Ready on Olevia's website although it's listed as HDTV on the sites it's sold at. From what I've read about HD-Ready, it seems that as long as I'm getting my HD channels from DirecTV (which will be the case) then HD-Ready is all I need. However, I'm wondering if I decide to buy an HD-DVD player down the road, will I also need to purchase a separate piece of equipment to use this with my TV? Any better explanations of what this HD-Ready means would help. Thanks.
Thanks for any help anyone can give.
-Ryan
) The set says HD-Ready on Olevia's website although it's listed as HDTV on the sites it's sold at. From what I've read about HD-Ready, it seems that as long as I'm getting my HD channels from DirecTV (which will be the case) then HD-Ready is all I need. However, I'm wondering if I decide to buy an HD-DVD player down the road, will I also need to purchase a separate piece of equipment to use this with my TV? Any better explanations of what this HD-Ready means would help. Thanks.Thanks for any help anyone can give.
-Ryan
