If you could mention the title, what country it was bought in, what the problem is and what firmware/driver your LG BH200 is running, it would be handy. Thanks in advance.
A Disc is not considered an LG BH200 Problem Disc, until it's been confirmed by more than one user. The Reported by only one user lists are purely for information.
Problem Discs:
Firmware BH02080620A - 2008-06-20:
Unless it says otherwise, titles have not been tested with other firmware!
* Reported by only one user:
1. 21, USA BD - The disc works fine (including the film) except for the "Blackjack" game, the game tries to load but then just returns to the main menu. See here.
2. Babysitters (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again, see here. The Blu-ray Disc works fine, see here.
3. The Brave One, USA BD - The disc spins for about 3 minutes, it then ejects and displays a "disc error" message. See here. The UK HD-DVD works fine, see here.
4. Bridge to Terabithia, French HD-DVD - The menu only half appears making navigation impossible and because of this the movie cannot be played. See here.
5. Debbie Does Dallas Again (Adult), USA HD-DVD - The pop-up menu cannot be disabled. See here and here.
6. Die Fledermaus, UK/USA HD-DVD - The menu loops and navigation is impossible, see here.
7. Les Gendarmes de Saint-Tropez, French HD-DVD - Discs 1-3: No menu appears & the playtime advances irregularly, the movies won't play. The Disc Four menu appears but doesn't work. See here.
8. Intoxicated (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here.
9. Island Fever 4 (Adult), USA HD-DVD - The Disc cannot be read and an is ejected with a Disc Error, see here.
10. Jesse's Juice (Adult), USA HD-DVD - Playback gets stuck in opening loop, menu appears but pressing Skip starts the loop over again. See here.
11. Pan's Labyrinth, UK HD-DVD - The Menu appears but cannot be navigated and no options can be started. See here. It's not known if the UK Blu-ray Disc exhibits the same problems. Working with January Firmware, see here. A workaround has been found for other firmware, see here.
12. Picture This from Mack Dawg Productions, USA HD-DVD Combo - The menu doesn't load (meaning extras cannot be accessed), the pop-up menu causes it to freeze, the main feature plays fine but if you fast forward it freezes, you cannot then eject the disc and have to put the LG BH200 into standby to fix this. See here.
13. Robbie Williams: Live at the Albert, UK HD-DVD - The menu loads but gets stuck in an opening loop preventing the Main Feature or Extras from being accessible. See here.
14. Robin Hood (2006), UK HD-DVD - The Menu loads but is very difficult to navigate, meaning no content can be accessed. See here. Working with January Firmware, see here. A workaround has been found for other firmware, see here and here.
15. Teagan: Sexual Freak 2 (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here.
16. Terminator 2: Judgement Day, German UE HD-DVD - The movie plays fine but the Interactive Web features don't work. See here.
17. Underworld: Evolution, German HD-DVD - It is not possible to disable the Spanish subtitles, see here.
18. UFO: Showtime, UK HD-DVD - The copyright text appears but then just a black screen, the menu will appear if the menu button is pressed but no options work. The disc then gets locked in player and requires a reboot. See here.
19. La Vie En Rose (La MĂ´me), French HD-DVD - Original Pressings: The BH200 tries to read it for about a minute then the Player shuts down, see here.
Remastered Pressings: The BH200 now reads it fine, however menu navigation is still impossible meaning you cannot select anything except Play (Audio and Subtitles can be changed using the remote control), see here and here. There is also a Blu-ray Disc, it's not known if this works.
* Reported by more than one user:
1. Clerks 2, USA HD-DVD - The disc loads and the menu graphic appears but no menu. See here and here.
2. Hotel Babylon: Series 1, UK HD-DVD - The Menu loads but is very difficult to navigate, meaning no content can be accessed. See here. Working with January Firmware, see here. A workaround has been found for other firmware, see here and here.
3. Kill Bill Volumes 1 & 2, USA BDs - The menu will not load when the BH200 is set to 1080P24 (Film Mode On), in all other display modes it is fine. Some have reported waiting and pressing the Menu button a few times works and others have reported clearing the BD Flash memory also fixes this. See here, here and here.
4. Madagascar, USA BD: "Loading" appears, the screen then goes black. The menu does not appear. See here and here. One user has reported it works fine, here.
5. Nine Inch Nails: Beside You In Time, USA HD-DVD - The TrueHD 5.1 outputs as 2 channel, see here, here and here.
6. Planet Earth: Complete Series, UK HD-DVD - All discs show the menu background but no options and navigation is impossible. See here and here. All other Planet Earth Blu-ray or HD-DVD Discs seem fine. The issue only affects the UK HD-DVD and the March, April or June Firmware (November and January firmware is fine). See here, here and here.
7. Shooter, USA HD-DVD - The menu loads but navigation is impossible and pressing Play causes the time to read 00000 but it doesn't advance past this, see here and here. Two users have reported it works fine, see here and here. Working with January Firmware, see here.
8. Wyatt Earp, USA HD-DVD - Extras don't work, an error occurs and the disc is ejected. See here and here. It's unknown if the Blu-ray disc exhibits the same problems.
Firmware BH02080402F - 2008-04-02:
1. Bridge to Terabithia, French HD-DVD - The menu only half appears making navigation impossible and because of this the movie cannot be played. See here.
2. Cloverfield, USA BD: The movie plays fine but the Easter egg "Military Cast" has jerky video. See here.
3. Enemy at the Gates (aka Stalingrad in France), French HD-DVD - The HD/BD lights flash trying to see which one it is, it's then spat out after 2 minutes, see here, here and here. It seems there was a Faulty Batch and a replacement disc should fix it, see here.
4. Fearless, UK HD-DVD - The menu loads fine and works but you cannot see the text so it's hard to navigate. However the Scenes, Languages and Bonus menus don't work. You can change subtitles using the remote. See here and here.
5. Die Fledermaus, UK/USA HD-DVD - The menu loops and navigation is impossible, see here.
6. Galapagos, USA BD - The disc spins for about 3 minutes, it then ejects and displays a "disc error" message. See here. The USA HD-DVD works fine, see here.
8. Nine Inch Nails: Beside You In Time, USA HD-DVD - The TrueHD 5.1 outputs as 2 channel, see here.
9. Intoxicated (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here.
11. Katyn, Polish HD-DVD - While the trying to determine if it's a HD-DVD/BD/DVD, the disc is spat out saying "Check Disc" on the TV and "Disc Error" on the Players display. See here. This maybe a faulty disc as other (Non-LG BH200) Players also have problems with this disc, see here.
12. Pan's Labyrinth, UK HD-DVD - The Menu appears but cannot be navigated and no options can be started. See here. It's not known if the UK Blu-ray Disc exhibits the same problems. Working with January Firmware, see here.
13. Picture This from Mack Dawg Productions, USA HD-DVD Combo - The menu doesn't load (meaning extras cannot be accessed), the pop-up menu causes it to freeze, the main feature plays fine but if you fast forward it freezes, you cannot then eject the disc and have to put the LG BH200 into standby to fix this. See here.
15. Shooter, USA HD-DVD - The menu loads but navigation is impossible and pressing Play causes the time to read 00000 but it doesn't advance past this, see here. Working with January Firmware, see here.
16. Superman Returns, USA Non-Combo HD-DVD - The movie plays fine but when trying to access the Special Features sub-menu a "Disc Error" occurs. See here and here. Working with June Firmware, see here.
17. Teagan: Sexual Freak 2 (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here.
18. Teagan's Juice (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here.
19. Terminator 2: Judgement Day, German UE HD-DVD - The movie plays fine but the Interactive Web features don't work. See here.
20. La Tigre e la Neve, Italian HD-DVD - Playback gets stuck in opening loop and after a minute of trying the disc, it is rejected. See here.
21. UFO: Showtime, UK HD-DVD - The copyright text appears but then just a black screen, the menu will appear if the menu button is pressed but no options work. The disc then gets locked in player and requires a reboot. See here.
22. La Vie En Rose (La MĂ´me), French HD-DVD - Original Pressings: The BH200 tries to read it for about a minute then the Player shuts down, see here.
Remastered Pressings: The BH200 now reads it fine, however menu navigation is still impossible meaning you cannot select anything except Play (Audio and Subtitles can be changed using the remote control), see here, here, here and here. There is also a Blu-ray Disc, it's not known if this works.
1. Babysitters (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again.See here, here and here. The Blu-ray Disc works fine, see here.
2. The Brave One, USA BD - The disc spins for about 3 minutes, it then ejects and displays a "disc error" message. See here and here.
3. Clerks 2, USA HD-DVD - The disc loads and the menu graphic appears but no menu. See here and here. Two users have reported it works fine, see here and here.
4. Hotel Babylon: Series 1, UK HD-DVD - The Menu loads but is very difficult to navigate, meaning no content can be accessed. See here and here. Working with January Firmware, see here. A workaround has been found for other firmware, see here and here.
5. Planet Earth: Complete Series, UK HD-DVD - All discs show the menu background but no options and navigation is impossible. See here, here and here.Working with January Firmware, see here and also working with the USA HD-DVD and April firmware, see here. The UK Blu-Ray Disc also works fine, see here.
Firmware BH02080314B - 2008-03-14:
1. 30 Days of Night, German BD - The Concorede logo (disc distributor) appears, the screen then goes black and nothing happens. Working with April Firmware, see here.
2. Afro Samurai, Japanese HD-DVD - 00:00:00 is displayed in the top right throughout, see here.
3. Babysitters (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here. The Blu-ray Disc works fine, see here.
4. Clerks 2, USA HD-DVD - The disc loads and the menu graphic appears but no menu. See here. One user has reported it works fine, see here.
5. Death Sentence (2007), German BD - The Concorde logo (disc distributor) appears, the screen then goes black and nothing happens. Working with April Firmware, see here.
6. Dragon Tiger Gate, Hong Kong BD - Playback gets stuck in opening loop and menu won't appear. See here.Working with April Firmware, see here.
7. First Blood (aka Rambo 1), Studio Canal HD-DVD - The pop-up menu (top left) continues to display during playback and cannot be removed. See here. FIXED see below!
8. Interactive Sex with Bree Olsen, USA HD-DVD - Multiple viewing angles flash/flicker, see here.Working with April Firmware, see here.
9. King Kong (1976), Studio Canal HD-DVD - The pop-up menu (top left) continues to display during playback and cannot be removed. See here. Working see below!
10. The Pianist, Studio Canal HD-DVD - The pop-up menu (top left) continues to display during playback and cannot be removed. See here. Working see below!
11. Rambo 2: First Blood, Studio Canal HD-DVD - The pop-up menu (top left) continues to display during playback and cannot be removed. See here. Working see below!
12. Rambo 3, Studio Canal HD-DVD - The pop-up menu (top left) continues to display during playback and cannot be removed. See here. Working see below!
13. Reservoir Dogs, Dutch HD-DVD - Either from DTS-HD MA or DD5.1 the audio is choppy and goes out of sync in places. See here and here.Working with April Firmware, see here.
14. Teagan's (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here.
15. Total Recall, Studio Canal HD-DVD - The pop-up menu (top left) continues to display during playback and cannot be removed. See here. Working see below!
16. The Triplets of Belleville, French HD-DVD - Green line issue on the right hand side of the screen, see here.
17. Tristan & Isolde, Dutch HD-DVD - Menu loads but you're unable to select anything (including the Subtitle menu) but can use the Remote to disable subtitles, see here.
18. La Vie En Rose (La MĂ´me), French HD-DVD - Original Pressings: The BH200 tries to read it for about a minute then the Player shuts down, see here.
Remastered Pressings: Untested but very likely to be the same results as the April firmware. There is also a Blu-ray Disc, it's not known if this works.
1. Enemy at the Gates (aka Stalingrad in France), French HD-DVD - The HD/BD lights flash trying to see which one it is, it's then spat out after 2 minutes, see here, here and here. It seems there was a Faulty Batch and a replacement disc should fix it, see here.
2. Terminator 2: Judgement Day, Studio Canal HD-DVD - The pop-up menu (top left) continues to display during playback and cannot be removed. See here and here. Working see below!
Studio Canal HD-DVDs: FIXED with Firmware versions BH02080402F (April) and BH02080124M (January). See here, here and here.
Firmware BH02080124M - 2008-01-24:
1. Debbie Does Dallas Again (Adult), USA HD-DVD - The pop-up menu cannot be disable, see here.
2. Die Fledermaus, German HD-DVD - The menu loops and navigation is impossible, see here.
3. Intoxicated (Adult), USA HD-DVD - Playback gets stuck in opening loop and menu won't appear, pressing Skip starts the loop over again. See here.
4. Jesse's Juice (Adult), USA HD-DVD - Playback gets stuck in opening loop, menu appears but pressing Skip starts the loop over again. See here.
5. Picture This from Mack Dawg Productions, USA HD-DVD Combo - The menu doesn't load (meaning extras cannot be accessed), the pop-up menu causes it to freeze, the main feature plays fine but if you fast forward it freezes, you cannot then eject the disc and have to put the LG BH200 into standby to fix this. See here.
6. Robbie Williams: Live at the Albert, UK HD-DVD - The menu loads but gets stuck in an opening loop preventing the Main Feature or Extras from being accessible. See here.
8. Top Gun, Swiss/German HD-DVD - The BH200 does not stop loading it and shows a black screen, see here. Working with March Firmware, here.
9. La Vie En Rose (La MĂ´me), French HD-DVD - Original & Remastered Pressings: The BH200 tries to read it for about a minute then the Player shuts down, see here and here. There is also a Blu-ray Disc, it's not known if this works.
None yet!
Firmware BH02071119P - 2007-11-19
1. La Vie En Rose (La MĂ´me), French HD-DVD - Original Pressings: The BH200 tries to read it for about a minute then the Player shuts down, see here. Remastered Pressings: Untested. There is also a Blu-ray Disc, it's not known if this works.
None yet!
Problem Discs:
None yet!
None yet!
And it really looks like he will never start to play the disc.
