Originally Posted by david.p
I'm using a BH200 connected to an Onkyo TX-SR500 via SPDIF and using the DTS Re-encode setting. I have a copy of Jurassic Park on DVD with DTS. I am unable to play the DTS soundtrack. On inserting the disc I see the menu presenting the choice between DTS and Dolby Digital, but selecting either one gives a DD Suround track.
This is with the March Firmware and loader 0702. I didn't try this disc before updating the player.
OK ... so, just a thought here; could the problem be that you have the BH200 set to DTS Re-encode and the audio coming from the disk is already DTS? I don't know, but it seems to me that it might prove problematic if the machine is trying to re-encode something that is already encoded as DTS. Perhaps you should try changing your audio settings to either PCM or Primary Pass-thru. That way, the BH200 should decode the DTS track internally and send it to your receiver or, maybe even better, in the case of Primary Pass-thru it will send it as a bitstream to your receiver for decoding.
Again, I have no idea if this will make a difference or not, it's just the first thing that came to mind. Good luck!
-C.
