Originally Posted by
oilblue
Argh. While I'm still on the May firmware, I can definitely confirm the problem on the UK version of PE (I purchased the set through Amazon.co.uk).
There is no May firmware. I think you mean April firmware (2nd of April).
oilblue
BTW, on the first page of this thread, please emphasize that these still don't work. I took the "fixed in January" to mean the problem was solved. D'oh. It's most clearly *not* fixed. Perhaps note that it's a "January only" situation. Thanks.
It's in the April and June problem disc list and says it's fixed with January firmware, they work fine with that firmware. I'll change wording to "Working" from "Fixed" though.
Planet Earth is a confusing one to list as:
UK HD-DVD: Works with the January firmware but not other firmware
UK BD: Works fine with all firmware
USA HD-DVD: Works fine with all firmware
USA BD: Works fine with all firmware (presumably)
Krobar
Yes it works. Please add this to the first page.
Done.
Krobar
Robin hood can start playback on chapter one by pressing enter. The menus are completely unusable.
I thought you said only Hotel Babylon allowed you to select chapters?
Krobar
Just for information, the UK HDDVDs of Galapagos and Brave One are fine. I have a copy of UK American Gangster HDDVD, will test it tomorrow.
Cheers.
Don Borvio
I know the Clerks 2 disc menus don't work, but can anyone tell me or point me to how just to get the movie to play if possible?
Have you tried selecting chapters manually, using the Skip button?
DoctorMaustus
That explains it. I have the 4-disc version with Attenborough. I wish I had the 5-disc set...anything good on there? Thanks for the clarification Brad.
No worries.
I don't know sorry. I don't own it period. I cannot find a UK review but here's what's extra:
http://www.dvdcompare.net/comparison....php?fid=10969
