post #1 of 1
Alright I have a quick question I have read a little bit about it on the 705 thread. I have a buzz on certain inputs through my subwoofer.
It only seems to be most apparent on the input I have running through the hdmi inputs on the reciever. Like my PS3 when I am watching a blu-ray in quiet scenes if the volume is up to much then I will here the slight hum.
On my HTPC though which is hooked up video through the HDMI on the reciever but the audio is hooked up via and optical cable and I do not hear the hum nearly as much or at all. I have to turn the volume up quite a bit and/or the gain on the subwoofer which I dont do normally other then just trying to figure this stuff out.
So just wondering what my options on fixing this problem. I have heard that the 805 doesnt do this but that option is kind of a pain for me but if there is not much else I might have to consider it more.
