Originally Posted by cb31
OK, I'm probably going to regret this but I'm going to buy a diva board as it is the only thing available in its class but I have a couple of questions first.
I fancy an Athlon X2 250 cpu, dual core 3.0GHz 65W TDP, which I presume is fine for Windows 7 MC with a couple of tuners and 1 xbox360 extender. It will also run a samba share so other computers can store data on its internal drives.
Do the latest boards come with a bios that will boot with that cpu? I don't want to buy another cpu just to upgrade the bios and I don't know anyone who has an amd cpu. I will be buying the board from www.ebuyer.com in the UK as I cannot find anywhere else that sells it.
Is DDR3 memory ok with this combination? It seems the same price as DDR2 so seems sensible to get 4GB of 1366 RAM. Thanks
I hope you won't regret it but from my personal experience you will. Still I have no idea how many people are using this board for more than a year without any glitch or defect. I guess that the ones who have these problems all comment in this forum. Typical about these remarks is that most of them say 'this is my 3rd or 4rd board..'.
Anyway, I just received my 3rd replacement and it didn't work. :-( I have to say that when I opened the box my first impression was that they have send me a used (and possibly) defect board. Stuff was missing and packages where open.
Your choice of processor can work with this motherboard as of BIOS 1.34.
http://www.msi.com/index.php?func=pr...=&prod_no=1654
Before you install you have to check what bios version is installed which you can find on the BIOS chip on the motherboard. There is a chip which says KMSx.xx (x.xx = 1.10/1.20/1.34). Some say that their processor didn't work so they had to buy or borrow and old processor just for upgrading the BIOS. You can find more information on this subject on the (unofficial) MSI forum. (http://forum-en.msi.com/index.php?topic=124174.0)
DDR3 memory is not supported. Only DDR2.
Be smart, don't buy ;-)
