I have a Marantz AV-560 receiver that seems to be on it's last legs, and I'm looking to replace it.
I'm looking for something that will drive two MA700 (fronts), and three MA500 (center and rears), Mono Amps. The amps drive Martin Logan SL3s (fronts), scripts (rears), and a cinema center speaker. I also have a Velodyne HGS-18 subwoofer.
I'm hoping that I can get some good advice from some knowledgeable folks here.
What I'm trying to decide is if it is better to replace just the AV-560, or the AV-560 AND the Mono Amps and drive the speakers directly (but that does not seem a cost effective direction).
What is a good bang-for-the-buck solution for replacing the AV-560? Suggestions?
Thanks in advance...
Brett
Brett
