Originally Posted by Quickster2
I need to perform further testing this weekend. In LPCM multi normal output via HDMI if it is a lossy codec including DD-EX and DTS-ES than the 3800 bitstreams this signal to my 4306. If it is a lossless codec than it sends it PCM (multi-channel in). To complicate the issue more, DTS-HD/HR is sent PCM to my 4306 but states only DTS on the 3800 and is only sending the core at 48khz. If I set the speakers for the LFE issue in the 3800 I risk "double dipping" the bass settings depending on the codec. A couple of Belhaven Scottish Ale's Saturday afternoon will get me to the bottom of this issue, if it is an issue at all. I had different results utilizing DVE essentials vs Blu-Ray's HD basics with the audio test tones.
Drinking you ale at Dick O'Dow's???
I picked up the Dolby TRUE HD demo disc from CES this year and it has a 7,1 TRUE HD test track. I just bought it on flea bay. I will get to the bottom of the potential LPCM LFE issue this weekend!
