Channel Master is rolling out a Digital to Analog TV converter which apparently is not CECB-certified. The web site indicates that "the CM-7000 Digital to Analog Converter is currently in production and will be available soon at your local electronics retailer."
CM certainly has a reputation for providing top-notch OTA products. However, I am concerned about the box's front branding as "HDTV Compatible" and "HD" (see picture on the information sheet).
Nothing indicates this box provides High Definition 720 or 1080 output. It should correctly bear the SDTV logo, not the HDTV logo with the legalistic phrase "compatible" in small print. I am also a bit disappointed that the product info sheet didn't provide ATSC reception specifications.
Anyone have more knowledge about this product, and why they have labeled this SD-only box as "HDTV" and "HD"?
