Setting Up Your SubWoofer 101
Here are some tips on setting up your sub(s).
Subwoofer Setup, Placement and Theories
Audioholics - Crawling for Bass - Subwoofer Placement
Audioholics - Subwoofer Placement Tips for Cabinetry Installations
Audioholics - An Easy Solution To Subwoofer Calibration
Audioholics - Bass Management Basics – Settings Made Simple
Audioholics - Subwoofer Placement Guidelines
Audioholics - Subwoofer Placement - The Place for Bass
Audioholics - Connecting a Subwoofer to a Receiver
Audioholics - Connecting a Subwoofer to a Receiver with No Subwoofer Output
Audioholics - Subwoofer Calibration Using Rives Audio Test CD 2
Audioholics - Setting the Subwoofer / LFE Crossover for Best Performance
Audioholics - Subwoofer Measurement Tactics: A Brief, Topical Overview & Method Comparison
Audioholics - Subwoofer Connection Guide For A Multi Subwoofer System
Axiom Audio - How to Find the Best Place for Your Subwoofer
HTF - The Misunderstood 0.1 LFE Channel in 5.1 by Brian Florian
HTF - Sub Placement & Setup by Tom Nousaine, Chu Gai
HTF - AVIA: Subwoofer Calibration by Guy Kuo
SVS - How Do I Use A Sound Level Meter To Calibrate My Subwoofer?
HSU - Calibrate A Sub With A HSU MBM-12 Mid Bass Module By Cyberbri
Common Subwoofer Set-Up Errors by Edward J M
Subwoofer Setup Guide by Bossobass
AVS - Ed Mullen's Subwoofer Setup Tips
AVS - What's the Big Deal About Crossovers?
AVS - LFE, Subwoofers and Interconnects Explained
HT HiFi - Bass Management Woes: Trouble on the Slopes
Audio Pulse - Myths About Subwoofers
Audio Innovation - Subwoofer Design Theories
Subwoofers: Optimum Number and Locations by Todd Welti
eCoustics - 68 Subwoofer Articles
Quick and Effective Sub Placement, Period! By Carl Kennedy
Sound Thinking - Floyd E. Toole, PhD - Audio White Papers
Speaker Setup, Using SPL Meter
Techlore - How To Calibrate Your Surround System Using an SPL Meter
Audiophilia - Essential Accessories: The Radio Shack Sound Pressure Level Meter
Audioholics - Setting Speaker Levels & Distance in a Surround Sound System
SVS - Radio Shack SPL Meter Compensation Chart
AVS - Radio Shack SPL Meter Correction Tables
Shakers, ButtKickers and Tranducers
AVS - Shakers - Simple/Cheap Hookup - Visual Guide
Sound Treatments and Acoustics
Audioholics - Introduction to Acoustics
Audioholics - DIY Absorbers for the Less-than-Handy Man
Audioholics - Acoustical Measurements - What are They?
Audioholics - A Guide to Sound Isolation and Noise Control
Audioholics - Room Acoustics: Isolation & Noise Control
Audioholics - Reducing HVAC Noise in Theater Rooms
Audioholics - Early Reflections in Home Theaters: A Different Perspective
Audioholics - Building Great Bass Response In Your Home Theater
Audioholics - Audyssey Labs' MultEQ
Audioholics - The Perfect Room?
Audioholics - Room Acoustics: Acoustic Treatments
Audioholics - Acoustics 101 Course by John Dahl of THX
Audioholics - Acoustics Facts and Fiction by Ethan Winer
Audioholics - Bass Traps - Not Just for Fisherman! by Ethan Winer
AVS - Acoustical Treatments Master Thread
HT HiFi's - Acoustical Room Treatment: A Survey of Methods and Materials
Loudspeakers and Rooms - Working Together by Floyd E. Toole from Harman
Maximizing Loudspeaker Performance In Rooms by Floyd E. Toole from Harman
Audio – Science in the Service of Art by Floyd E. Toole from Harman
Jon Risch's DIY Acoustic Treatments
AVS - Video On Cutting Rigid Fiberglass for Bass Traps
Bob Gold's Absorption Coefficients
Acoustic Treatment and Design for Recording Studios and Listening Rooms by Ethan Winer
Real Traps - Acoustic Treatment Overview
ATS Acoustics - Sound Absorption and Acoustical Panel FAQ's
GIK Acoustics - Acoustics Primer - Some Basics On Acoustics
Ready Acoustics - Acoustical Primer
Sensible Sound Solutions
Sonopan Acoustics
Quiet Rock - THX Certified Drywall
Green Glue
Auralex SubDude
Owens Corning Rigid Fiberglass 700 Series Insulation
Equipment
Behringer Feedback Destroyer Pro DSP1124P
HTS - BFD Guide
HTS - BFD Links
Audioholics - Active Room Correction: A Primer to Audyssey MultEQ Pro
Sound Pressure Level (SPL) Meters
Radio Shack Digital-Display Sound-Level Meter
Radio Shack Analog Display Sound Level Meter
SVS's Radio Shack SPL Meter Compensation Chart
CHECK MATE Series Of SPL's
Software
Ovation Multimedia - Avia II: Guide To Home Theater DVD
Digital Video Essentials: Get The Most Out Of Your Home Entertainment System DVD
AVS - jeffreylebowski's Free Software for First Reflection Points
AVS - Room EQ Wizard Help Thread
HTS - Room EQ Wizard
HTS - BFD Guide
HTS's BFD Links
SPL Calculator by C.M.Collins
Harman Kardon - Waves & Modes-A Room Resonances Locater (XLS spreadsheet)
TrueRTA Audio Spectrum Analyzer
AVS - TrueRTA For Dummies
Audio Spectrum Analyzer - Spectrum Lab (Waterfall Chart)
Test Tones, DVD's
Realm Of Excursion (Download Section)
RealTraps - Test Tone CD
Bink Audio Test CD
Stay in Tune with PentaTone
AVS - DIY Audio Test DVD
VB-Audio - Sine Wave Generator - "LF Generator"
Ground Loops and Hum
Audioholics - Thinking in Isolation – A Primer on Ground Loops
Audioholics - Ground Loops - Eliminating System Hum and Buzz
HUM FAQ by Bill Lummus
Home Tech - RF Attenuators, Filters, & DC Blockers
Impact Acoustics - Isolation Transformers
For more Info on Setting Up the rest of your Home Theater, see these threads:
http://www.avsforum.com/avs-vb/showt...2#post10118822
http://www.avsforum.com/avs-vb/showthread.php?t=1045531
