Every time I go into Display Profiles...Configure, change the resolution with the slider and click on "Advanced Timing Options" it brings up the properties for the default resolution (1280 x 720). Before clicking the Advanced Timing Options I click Apply and Windows actually does switch to the newly set resolution. The only problem is that I can't tweak the settings since Powerstrip always stays at the same resolution. If I hover over the Powerstrip icon in the Taskbar it always reports 1280x720, once again even if Windows reports the resolution as something else.
Has anyone else experienced this?
Thanks in advance.
Windows Vista 32-bit
Asus EAH3650
Toshiba 46H83 Rear Projection CRT connected with DVI
Chris
Thanks in advance.
Asus EAH3650
Chris
