Originally Posted by Hogganbeck
I'm very close to picking up one of the W4S stereo amps based on great reviews and the responsiveness of EJ on this thread. Seems like a company really worth supporting. I'm trying to decide between the ST-250 and ST-500. My speakers are a fairly easy load (8ohm, 93dB sens). I'm thinking the 250 would be more than sufficient, but would there anything to be gained by going up to the 500?
Also interested in impressions of the sonic character of these amps. I'm hoping to match or beat my ARC 100.2 in terms of sweet highs, great slam factor, deep and tuneful bass. Any comments on the ST amps in this regard?
Finally, I plan to pair it with a PS Audio GCP-200 preamp. Any opinions on how this pre would mate up with the W4S amps? Any comments on how the GCP might stack up against the new W4S pre?
Thanks for your input.
I'm sure others will reply but my first suggestion is to ask EJ. Second, you can never have two much power. Third, if you ever switch to speakers that do present a tougher load with more you won't have to change (ie See point 2).
Can't comment on what you are mating them with but my experince with the MC channel has been outstanding. The "slam" is there, and then some as for mids I've found them to be clear, not forward and not rolled off just clear and non-fatiguing. The highs will depend on you. I've had some very open electronic amps matched with speakers that would either smooth them or add to the openness. In my younger years that was very interesting and very revealing but I found 2 isses with the extreme openness of other amps 1) Listening fatigue 2) challanges with finding good source material. So I now lean towards a more liquid top end that is revealing without the fatigue. The W4S does that for me and still is very open (ie not layed back) but others may be wanting for even more. I haven't had a chance to try my amp with more revealing speakers - I'm finishing up a room redo - but that type of a change may add to the openness without becoming to brittle. Will have to wait and see.
