I'm not sure why this isn't more highly publicized, but Bruce Mitchell is creating a small converter, 4.5"x3"x1" that converts Infrared to Bluetooth allowing any IR-based universal controller to work with the Playstation 3, with the ability to turn on/off via remote.
www dot ir2bt dot com
No need to do any external installations, just plug in the converter box somewhere, either to your PS3 usb, or to a plug via external power jack, pair your PS3 with the converter box, and it will convert all IR commands to bluetooth.
Not quite ready for production yet, but might be worth taking a look at.
Regards.
Regards.
