Here's the way to enter the service mode on the Toshiba XF550 (U) series.
* Turn the TV on.
* Press the {MUTE} button on the remote and hold. Edited 4/4/08: As you stand close to the TV, make certain that you hold the remote low enough so that the TVs infrared receiver (located near the lower right corner of the front bezel) is able to see the signal from the remote.
* Then press the {MENU} button on the TV's side panel.
* Release both buttons.
* There should be a red letter "S" on the upper left of the screen, with the Service Menu adjustment box next to it.
* Use the {CH+} and {CH-} buttons to select the parameter of interest. (You can use the side panel buttons or the remote buttons.)
* Use the {VOL+} and {VOL-} buttons to change settings. (You can use the side panel buttons or the remote buttons. You can also use the up and down arrows on the remote's menu/channel selection circular control pad. Take care not to accidentally use the volume buttons or the up and down arrows in the central control pad before you write down all the default Service Menu parameter settings.)
* Use the {EXIT} button on the remote to temporaily make the Service Menu adjustment box disappear. (The red letter "S" stays visible.) You can now adjust volume, change channels, freeze, etc.
* Use the {MENU} button (remote or side panel) to show the Service Menu box again. You'll also be returned to the first selection (R-CUT).
* To exit, turn the power off.
There are 22 service menu parameters available:
R-CUT
G-CUT
B-CUT
R-DRV
G-DRV
B-DRV
BRTC (BRIGHTNESS CENTER)
COLC (COLOR CENTER)
UVTT (BASE BAND TINT)
CNTX (CONTRAST MAX)
SHRC (SHARPNESS CENTER)
VBIS (VERTICAL BLANKING INTERVAL SETTING)
CC (CLOSED CAPTION)
ID1 (VBID)
GG (GEMSTAR GUIDE)
OPT1 (SET OPTION 1)
OPT2 (SET OPTION 2)
OPT3 (SET OPTION 3)
OPT4 (SET OPTION 4)
OPT5 (SET OPTION 5)
SETID
VOLX (VOLUME MAX) - Typically used to set a maximum volume level for a hotel room
Also, when in the service menu you can press the {9} button on the remote and get a series of elaborate menus showing a great variety of dynamic system parameters and self-check codes. One of the parameters is the number of hours the set has been used. You can press the {EXIT} button on the remote to return to the "S" only (the red letter S in the upper left of the screen) level of the Service Menu...that is, you then have to press {MENU} to get back to the regular Service Menu parameter screen.
Edited 3/22/08: There are two hidden openings on the back of the XF550 series. These openings are accessible after removing a metal plate next to the HDMI ports (one phillips screw). Neither opening is a USB port, and the actual purpose of these hidden access points is unknown at this time (but, see edit 3/26/08 and 7/25/09 below). One is a round hole with a recessed connector or adjustable mechanical device inside the set. It may be an optical port. The other opening is a narrow rectangular slot, but without an obvious connector visible. The openings are rather hard to see even after removing the metal cover plate.
Edited 3/23/08: Another service menu setting control was found...All the menu parameters which show an actual hex code address (not just "----") allow that address to be changed in its most significant digit (MSD) position. The address can be changed from 0XXXH to 3XXXH by depressing the {CH RET} remote control button. Each depression advances through the 4 possibilities and then returns to the starting address of 0XXXH. The data at the 4 address for each parameter is the same...at least it is on the factory default settings on my set.
Edited 3/24/08: When cycling between the service menu parameters R-CUT and VOLX, you may experience a considerable delay in the TV screen update. Just be patient as the computer inside "does its thing". The delay can be up to 8 seconds or so.
Edited 3/26/08: I guess it pays to read the manual. I just found this info on page 11 of the user's manual. Note item 10...it's identified as a service port for updating the TV's firmware. This is one of the hidden connectors I mentioned on my 3/22/08 edit above.
Edited 4/6/08: While adjusting the three drive settings (R-, G-, & B-DRV), the internal processing does take a bit of time to respond to the new setting. There can be a three to four second delay before the screen will adjust itself to the new setting.
Edited 7/25/09: The narrow rectangular service slot has an SD card connection port inside. The SD card will be inserted vertically into the internal connector. The SD card goes in with the printing on the top of the card facing towards the rear of the TV set. The card goes in (upwards) only about half the length of the card. The insertion is very easy and smooth...no significant pressure need be applied. See posts later in this thread for a link to the upgrade firmware available in a zip file. (Post #301 has the link... http://support.toshiba.ca/support/ce...oads/index.asp ...Thanks, Italiano) You will have to unzip the file and load the program onto an SD card (a 1 GB card works fine). The newer firmware (October '08) does allow the R-, G-, and B-Cuts to be adjusted. Prior firmware would not allow these adjustments even though the numerical value of the setting was changed.
WARNING!
YOU CAN REALLY SCREW THINGS UP IF YOU CHANGE SERVICE MENU SETTINGS IMPROPERLY!
WRITE DOWN EVERY PARAMETER'S HEX CODE (OR BINARY CODE) BEFORE CHANGING ANYTHING!
You can do more harm than good by entering the service menu if you don't know exactly what you are doing.
ADDITIONAL WARNING
Each time you enter the Service Menu to view or change the default factory settings there is a count made of each "read" and/or "write" of any parameter you view. Even simply reading each of the parameters is counted. This count (actually different counts for the number of reads and writes) is saved in Non-Volatile "EEPROM" memory. These values are available for display in the Service Menu's special "Dynamic system and Self-Check Codes" menus.
Be aware that entering the Service Menu, even if you don't change anything, is recorded in this "NV Memory" window. An authorized service technician can obviously see whether or not you've entered this area of the set's adjustments. Toshiba's service personnel could get really sticky about "voiding the warranty" because we've decided to fix things on our own.
ADDITIONAL WARNING
* Turn the TV on.
R-CUT
G-CUT
B-CUT
R-DRV
G-DRV
B-DRV
COLC (COLOR CENTER)
CNTX (CONTRAST MAX)
CC (CLOSED CAPTION)
ID1 (VBID)
GG (GEMSTAR GUIDE)
OPT1 (SET OPTION 1)
OPT2 (SET OPTION 2)
OPT3 (SET OPTION 3)
OPT4 (SET OPTION 4)
OPT5 (SET OPTION 5)
SETID
