Ok i se your poit , thanks a lot guys .
I'lll just use mine g-22k's phono stage at this time .!!! thank's guys.
Normally, such frivolities are frowned upon.
) and rears will be Energy Pro 3.5's(PDF 600kb).
). I think that will work fine for your side surrounds. My potential concern (and it's not a big one) about your rears would be if you're sitting to close to them for the sound from the Energy's drivers to disperse properly for a proper tonal balance (example: if you're sitting a meter from speakers elevated two meters above the floor). Audyssey, may be able to compensate for this via equalization, or perhaps you could point the Energy's toward your listening position. Again, this only applies if you're too close the the rears. If you have some distance they should work just fine too.
speakers, would you say they would be better placed in front, in line or just behind seating position. Then what height. I'm not disregarding the previous responses, just after Franks op' as he had similar speakers. The other query would be are the Aaron's best for the Sides and the Energy's for the rears or vice versa.
