If anyone else is as anal as I am, here is a link to an EXCEL spreadsheet where you can keep track of your AVP settings. It has some drop down menus and it is "pretty cool" (thus sayeth Hanna Montana).
http://attachments.wetpaintserv.us/2...07g%3D%3D19255
This is courtesy of http://avppoaowners.wetpaint.com/page/Setup
I have my settings on 3x5 cards now but with the upcoming upgrade, I might do the Excel thing and also take a bunch of screen shots to make sure I get it back to where it is now. I'm sure some of the menus will change with the new update but at least I'll have a starting point instead of doing it all over from scratch. Will also have something to compare to.
, For me it only makes sense to even considering bi-amping the 3 fronts that take the most power. The reason why the 10 channels on the POA are so nice is that most will go for a 7.x setup use 6 amps for the fronts and 4 for the surrounds. This is why your question is not a easy one and why i (if you like your current amp) look for more of the same model/brand. Unless you want to get 1 POA you might run into troubles outlined by jackox.
