THANKS!
The wireless HD to replace an HDMI cable is good to know. I just ran the HDMI cable for the media room I am building. I have been debating between a permanent drywall ceiling and a suspended ceiling. The drywall costs less but I was worried about what i would do if I ever needed to run more wire or change a cable. Looks like wire for low power applications may finally be on the way out.
To hi-jack your contribution I thought I ought mention that I had Huppins (One-Call) in Spokane do my upgrade. I had bought it from them several months ago and asked them to hold it but as I recall it came in stock less than 2 weeks; they held for me until I was ready to install (it's a long story--I moved from Illinois to Idaho). They did the install overnight and had been willing to do it in one day of I got the AVP there before 10AM. I told them to take their time because I didn't want to sit around Spokane all day. They told that they had done 3 or 4 of the AVP upgrades. Huppins has an excellent service dept. Of course I couldn't check their work since the HT room isn't done. Maybe by Christmas we will be trying out the upgrade.
For now I need to order some drywall....thanks again
Edited by AudioBear - 9/8/12 at 7:15pm
., always quick with an answer. So When I go through the menu to the firmware set up, there is not option for "check for update". I simply plugged the ethernet cable in and didnt bother setting anything up network wise. Im guessing you have to set up the denon with the network, I am reading through the manual now about that.
