Originally Posted by Digione
..The only problem that I have with my AVP is that once it is set to auto for HDMI input mode, it needs this in order to activate DL4, it always resets itself to HDMI digital input mode when I play any other disc. This means every time I want to use DL4 I need to set the HDMI input mode to Auto again. Have you seen this issue?
So what you are seeing is right if I understand you correctly.
FWIW, I have the DBP A100 (4010) connected via HDMI & DL (CAT5) to the AVR A100 (4311) . It seemlessly and correctly switches back and forth from DL4 BluRay to DL3 function for other discs without any fiddling of HDMI input mode.
), and I've been a longtime fan of TriField (on my old Meridian pre), so I tend to listen in multichannel most of the time.
that Roger Dressler isn't a fan of bridging, but what do others think about the 2 options and Roger, what do you think about biamping?
- I would think they would be able to look up whether it's a refurb based on the serial number. But we'll see what they say. In the meantime, Denon has advised me not to remove the POA from the plastic wrapping. It looks like my Christmas present to myself is turning into a bit of a PITA
