I have a Marantz UD9004 and a AVP-A1HDCI. No body talks on the UD9004 forum so I ask here. Want to play SACD multi and 2ch with the best audio possible with a minimum of menu changes on both UD & AVP.
Connected XLR outs to AVP, selected CD and selected XLR. Have HDMI1 out to DVD on AVP.
Never been able to play SACD till now. I'm a virgin.
Review I read said "To wrestle full control over the UD9004’s multichannel analogue outputs you’ll need to go to HDMI Setup >Audio Setup and set this to ‘Mute’ before returning to the top Audio Setup menu where the (analogue) 7.1 channel level and distance options then become available. To enable the speaker configuration options (speaker size and crossover frequency) the Source Direct mode needs to be switched from ‘On:50kHz/100kHz’ to ‘Off’. Only now may you fully configure the UD9004 as a standalone source offering 7.1 channels of analogue sound from its RCA/XLR connections and 1080p/60Hz/24Hz digital video over HDMI."
To wrestle full control over the UD9004’s multichannel analogue outputs you’ll need to go to HDMI Setup >Audio Setup and set this to ‘Mute’ before returning to the top Audio Setup menu where the (analogue) 7.1 channel level and distance options then become available. To enable the speaker configuration options (speaker size and crossover frequency) the Source Direct mode needs to be switched from ‘On:50kHz/100kHz’ to ‘Off’. Only now may you fully configure the UD9004 as a standalone source offering 7.1 channels of analogue sound from its RCA/XLR connections and 1080p/60Hz/24Hz digital video over HDMI. http://www.hifinews.co.uk/news/article/marantz-ud9004-pound;5000/7602
This works but changes all the settings so I can't play blu ray, no video at all. Plus can't see menus, most DVD-A or SACD have a menu to select sound format options. Have to select menu option from DVD input where video is available then switch to CD input on AVP to get the sound.
I must be way off. I can't believe this is how it's expected to do this. Also some of my disks are live concerts, I want best audio with video also playing. Is this even possible?
Can I use HDMI2 for video only to CD input on AVP and XLR for audio. Is that what I'm missing?
Edited by dahlgren - 1/10/13 at 9:07am
you don't use a menu with SACD's.
I'd suggest the KISS approach, use HDMI and that also gives you everything.
