Thnx for the quote and I think we agree that it is in fact NOT "absolutely necessary if you listen at any volume level below reference (0 dB). It must always be on to make sure the balance is maintained at lower listening levels."Originally Posted by Ganymed4
Let me see, if I can find it in Ask Audyssey.
Sorry, I can't publish the link here due to privacy reasons.
The whole Answer from Chris was:
...Dynamic EQ is absolutely necessary if you listen at any volume level below reference (0 dB). It must always be on to make sure the balance is maintained at lower listening levels.
Don't worry about the subwoofer dynamic range. It doesn't matter where the level on the sub is set. It's just a relative setting."....
Listening to the sound of 'Dredd' in 9.2 with the AVP was just exactly what I always wanted to hear. I hope this answers your question. In doubt, please use Ask Audyssey.
But at the end, you are right, it is absolutely optional. However, I found it most helpful, if you are using XT32. For XT, I would find it too much. Or in other words: There is a difference in the implementation of DEQ in XT and XT32.
I like DEQ but it is an optional EQ tweak. It performs its intended EQ function quite accurately for film. However for music it often produces inbalance in two major ways. One, it can boost the bass too much, so usually requires adjustment to the track by use of RLO, as I'm sure you're aware. With MC music it boosts surrounds way too much and IME even using the proper RLO setting to tame the bass is not enough. For MC music, having to tweak RLO and then tweak the fader is too much trouble for me. So for MC music I just turn off DEQ and turn up MV.
I do not not take Chris' statement quite so literally in this ex.
Sometimes a simple thing like that can drive you crazy.
