Discovered the analog input problem, well at least for me.
When the manual says "non standard signals may not be converted", they really mean it. The Y/C and composite signals that I was using had the luminance way too high 100IRE = 115 IRE and that is definitely non standard. So I tried my old Sony S-VHS machine, SLV-R1000, and everything worked just fine. The HDMI up converted output burst into life from any Y/C or composite input.
So for those having problems make sure that your Y/C and composite signals meet NTSC specifications; level and frequency. It looks like the AVP is really anal about it.
If your analog video input appears on the analog monitor out but NOT on HDMI, then assuming that you have set up video convert on the input correctly you can reasonably assume that there is something wrong with the signal you are feeding the AVP. What I saw was smearing on the peak whites on the analog monitor. The composite monitor video output does not seem to care too much about a non-standard analog input signal as it is all analog video circuitry.
Edited by Digione - 3/8/13 at 2:07pm
