Originally Posted by Ganymed4
Meanwhile I tested for you. It is as I wrote. I have about seven multichannel classical FLAC files two are 5.1, five are 5.0 - as you wrote. I can see that if I use 'Multichannel Direct' that in the input there are only five channels but the output shows 6, plus the subwoofer. However, there is no sound from the subwoofer. Exactly as you wrote.
Thank you once again Ganymed4. I have checked your findings and agree that the simple solution is to select straight MCH replay and not use Direct. The sub is then doing its job exactly as it should. Since I have already got one of my Quick Select buttons programmed to do Direct and another to do non-Direct, I am already well prepared
Your effort to advise is much appreciated.
