Originally Posted by StephenBishop
I think I found the answer in the ps3 Forum. Here's a quote from one of the posts:
"If you are waiting for bitstreaming of the HD codecs (TrueHD and Master Audio) via HDMI, you will be dissapointed...the HDMI chip on the PS3 is incapable of streaming HD audio. Its a hardware issue, not a software issue that could be addressed with a firmware update. The best you can hope for is internal decoding of DTS-HD Master Audio and LPCM output via HDMI, which is how the PS3 currently handles TrueHD and Dolby Digital Plus. By the way, the PS3 already can decode and playback ALL Dolby codecs, either in 5.1 or 7.1 format. ......."
So it appears the TrueHD is internally decoded by the ps3 and then transported via PCM.
Thats correct. Leave it at PCM. Your display should say Multi ch in.
