Thanks, Wilfred...but the hard power switch is toggled correctly.
And yes it is as comfortable as it looks.
I tried out the Buttkicker feature (using the "Transducer" option in the AVP) and it worked great! I had to fiddle with the settings a bit as initially it was a bit too much and it was a bit distracting instead of complimenting. I still need to fine tune it but now it really adds to the whole experience.
I haven't yet tried it with music, so I don't know if I will like it with that or not.
Thanks for sharing that!
A star-quad design like the Canare uses twisted pairs, yielding the better noise rejection characteristics. The Belden uses single-wire conductors. But I think they are both excellent cables and I wouldn't expect to hear any difference in actual use. The Canare would probably be a better choice for a "noisy" environment (for example, where lots of other cables, especially power cables, run parallel with the interconnects...). I personally use a star-quad design (not Canare though) in my XLRs, but I'd be comfortable with either type.
If I do decide to pass on the POA, I have no problem sharing the name of the dealer so someone else can get a crack at the POA.
I replaced my HTS 7.1 with the AVP and am pleased with the sound but somewhat overwhelmed with it's capaility.
It has a very favorable sound to the Krell processor in the areas of dynamics and detail. Also built like a Krell!
