AVS › AVS Forum › Display Devices › Display Calibration › Horizontal Banding on RPTV
post #1 of 6
Recently I've noticed, in this case while playing SSB: Brawl, that there are horizontal bands, maybe an inch apart from each other, that appear in dark sections of the screen - most easily seen in greys. They appear to travel down the screen somewhat quickly. Lowering the brightness doesn't help -- they are still prevalent.
I haven't tried with other inputs, but this is with a Nintendo Wii connected with component cables (third-party) running in 480p on a 47X54 Panasonic RPTV. Are the cables to blame? Or is there some sort of interference?
post #2 of 6
If they are moving it sounds like a ground loop.
post #3 of 6
How do I fix a ground loop?
post #4 of 6
Maybe this will help:
I have the TV plugged into one outlet - it's a 3-prong plug. I have a power strip plugged into the same outlet, with a receiver, DVD player, Wii and 360 getting power from that. The subwoofer is plugged into a separate outlet. The cable comes from the wall, but there is a connection between two separate cables. I thought that might be the problem, but disconnecting the cable doesn't change anything.
post #5 of 6
Anyone know anything about ground loops?
post #6 of 6
If you do a search on ground loops you will find lots of articles. Usually the cable feed is the main culprit.
