I know people don't like those annoying new threads from people who are not able to use the search button, but I feel my problem needs some special attention. I have tried asking in my local reception thread, but it only gets maybe one post a day and it's not people that will help.
I recently got a new magnavox CECB from Wal-Mart to hook up to my Panasonic "HD Ready" TV. I am in an area that is fringe at best, with no obstructions and very flat. I have an old VERY large Channel Master antenna(not sure of the model but it resembles this one: http://salestores.com/chma36ulhitv.html) on a best guess 40' pole. I can post an actual picture if need be. It has a rotor and a small black box between the rotor and antenna. The black box, I assume, is a preamp(It says channel master but that is all I can read). The cable coming from the antenna is that old flat brown wire that resembles speaker wire. It runs probably a total of 60' to a Channel Master 0063C preamp power supply by the TV.
Here are my results from TVfool: http://www.tvfool.com/index.php?opti...pper&Itemid=29. I get very strong signals on the first three channels, a 10% on WSIL, and 30% WTCT. Nothing else has a signal.
Here is what I want to know:
1. Should I be able to get more channels(namely fox, cbs, and a stronger abc signal)?
2. Is my current setup optimal for my antenna?
3. Is that flat brown wire the best choice for a digital signal?
4. What new equipment would help?
My apologies for the long post; thank you for reading it and for any help you may be able to provide. I hope I have supplied you with all the information you need.
Save the results to your computer (it's a .png image), then post it as an attachment using the "Manage Attachments" button in the "Additional Options" section of the forum reply screen.
