AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › BD-UP5000 problem discs
BD-UP5000 problem discs - Page 5
post #121 of 1308
Originally Posted by vinnie97 View Post
Thanks guys...I'll be giving it a strikethrough, I think. Do you have any other Blu-ray player to compare Pobff?
Ill be testing out Bee Movie as well....Ill be back later tonight
post #122 of 1308
I don't think using a PS3 would be a fair comparison. (My samsung is with my 52" which is at the condo in fremont and I only go there 2 times a week whereas my LG is with my 32" in san jose)
post #123 of 1308
Tested Spiderman 3, I didnt see anything out of the normal. The menus navigated normally, even when selecting items.
Bee MOvie: This loaded a little slower then normal, and began with a black Screen, after a fwe seconds it loaded without issue and I was able to navigate the menus no problem.....
post #124 of 1308
Why then will it not work on my system - and since the 1.3 firmware update-no loading for other movies as well - what do I need to do? THis is really frustrating! Bee Movie does not load on my system. I get the error code 0x000000ff. Does this mean anything? Can we reset this system to get it to work - and reinstall 1.0, 1.1, 1.2 and then reinstall 1.3? PS3 is looking more and more attractive!
post #125 of 1308
Generally this error code deals with an inability to read or decode - but it may mean something different with this player. Any thoughts?
post #126 of 1308
Bee MOvie: This loaded a little slower then normal, and began with a black Screen, after a fwe seconds it loaded without issue and I was able to navigate the menus no problem.....[/quote]
Dear Ph8te: I tried re-installing the firmware update - now on the third time. No deal. Will try again. I'll let you know if it works. Consequently, Bee Movie is not the only one it will not load - so far - no load for Ice Age and Ratatouille. They used to load on the 1.2 firmware update. Do you know if you could re-install the prior firmwares to attempt to correct the issue? Downflash-so to speak- to a prior firmware (one that was stable on my system)?
post #127 of 1308
Tried reinstalling the firmware 1.3 over 5 times now and still no deal. Bee Movie does not load, Ice Age does not load and others...I am going thru my collection (now worthless until I get the PS3) and will update what other movies do not work. This system is garbage. Until it is stable - it is a waste of time and money. Could have saved hundreds of dollars if I would have bought the PS3! Extremely frustrated and Samsung offers no support (except script readers from Pakistan or the Phillipines)!
Any help would be greatly appreciated!
THanks,
JET
post #128 of 1308
Might be the player itself.....YOu can try to reinstall 1.3 over 1.3 by using a CD for firmware update...
post #129 of 1308
Tried reinstalling 1.3 several times and it did not work. 1.2 played all the prior movies, so why would it be the player. Ratatouille and Ice Age worked prior to the 1.3 update. Still frustrated.
post #130 of 1308
Does anyone know where I can get firmware 1.1?
post #131 of 1308
Thanks for moving the discussion over here, Jet. It does sound like you have a player that was compromised in some way. I'll let you know if Ratatouille loads over here. I'm sure someone here saved the older firmwares but 1.1 ended up breaking the network feature of the 5000 and is supposedly identical to 1.2 in every other way.
post #132 of 1308
I have to agree, either there is something we are missing, or the player needs to be repaired......
post #133 of 1308
I am going to try a dvd lens cleaner and see if it fixes the problem. If it works all around, don't see why it shouldn't with mine. If the lens cleaner does not fix it, will call samsung to send it in and get it fixed.
Thanks for your help. Will keep you posted.
post #134 of 1308
BD Rambo (the new one that takes place in Burma):
I heard quite a few dropouts at various points during the film when using spdif output and "Audiophile" mode. "Most" of these dropouts were completely repeatable, but I did hear a couple that did not happen when I backed up and re-played the same section. If anyone wants to test this, I found a spot with two dropouts in close succession:
Chapter 2 at 8:17, and then at 8:25.
The two dropouts were repeatable for me, but they ONLY happened when in Audiophile mode. When I switched to Re-encode mode, they no longer happened.
I also saw some strange visual oddities at one point:
Chapter 8, from 43:52 to 44:13. As the team walks up the hill to the cave, and then through the cave, the motion on some shots stutters, as if there is a pattern of missing frames in these shots. The movement of characters across the screen is not smooth -- it has little "jumps" in the movement at regular intervals. This only seems to happen on certain shots in this scene, and I did not notice it in any other scene. As soon as we cut from the cave to the plants in the water, the issue stops.
Also, I noticed some glitches with the bonus view feature. While it was on, when I would pull up the menu to change chapters, the words "Chapter Selection," as well as the little chapter stills, were missing. If I navigated around a bit the text and stills would return.
Larry
post #135 of 1308
Vinnie: Is the list now back up to date (as much as it can be) following firmware 1.3? Thanks.
post #136 of 1308
I think so...but I won't admit to that with 100% certainty.
BTW, thanks Larry!
post #137 of 1308
Thanks Vinnie.
post #138 of 1308
Hi,
I haven't watched it all the way through, so maybe I should do that first, but I just wanted to report that my Clerks2 plays through 1:04:44.
Something weird does happen at that point though. The counter stops counting, but the video and audio continue fine without any hiccups. The counter then continues around 1:04:48, so it's like the counter hangs for 4 seconds.
The other interesting thing is that the player get's louder at that point (by louder, I mean physical drive noise - is it switching to a different layer?)
And the increase in volume of the drive occurs whether you let the machine play through that point in time, or if you just chapter skip past the time.
If i recall, there was a chapter stop around 1:02, and the next chaper is around 1:08. If I cue up the one at 1:02, it's pretty quiet, and if I skip to the next chapter, I can hear the drive is louder.
Do this happen for other people, or just me?
05) Clerks II (HD DVD) : issue at 1:04:44 (able to duplicate going both FW/BK). Blk screen, "freezes", then continues as normal *unchanged*
post #139 of 1308
Originally Posted by stpat View Post
Hi,
Stpat,
the reason itson the list is becasue it happens to more than 1 user. The Clerks 2 issue is a carry over from earlier firmwares that was never fixed. While you may not always see the black screen, the unit "pauses" at the mentioned time point then continues on normally. THis is the only point in the movie that this occurs so no worries about the rest of the movie.......
post #140 of 1308
Hi,
Yes, I was just pointing out that my screen doesn't go black as reported, and the only thing that pauses for me is the counter... the video and audio continue to play fine through that point.
I just thought it was interesting.
-Stuart
Stpat,
post #141 of 1308
Ph8te, I only remember you reporting this ...I might have to take it off, could be down to disc authoring or player differences.
post #142 of 1308
Actually it was another user who reported it I only verified it.......There is definately a problem with it though that is repeatable....I do know that the error doesnt happen the same way all the time though. Sometimes there is no black screen, sometimes there is, just a luck of the draw....
post #143 of 1308
Yup...I wonder if the error exists on other hardware (the BH200 has been known to hiccup on it as well). I wonder how Toshiba hardware handles it. Maybe it's time to break down and buy the thing to test.
post #144 of 1308
LOL.....I would rent this one if you are not a fan of the type of comedy.....I watched it on the Add-On with no glitches that I can remember....
post #145 of 1308
Well, who still rents HD DVDs? lol I guess Netflix and Blockbuster Online but I don't have accounts with either. With the current deal at DeepDiscount, the effective price is down to $6.40. It's tempting but I'm not a big fan of Kevin Smith nor his brand of trashy humor.
post #146 of 1308
Anyone have problems playing Semi Pro on BD. Mine freezes on the menu.
post #147 of 1308
post #148 of 1308
Could be...
Upgraded this weekend and SEMI PRO played flawlessly....
Also, this version fixes the HD-DVD import version of FANTASTIC FOUR: SILVER SURFER disc... Have never been able to get it to play in ANY player.... Niether the A1 or the 5000 would play more than 5 minutes before freezing up....
Plays fine now!
Chris
post #149 of 1308
I figured out why Semi Pro was not playing on my player. I rented this movie again today and had the same problem movie will not play. It was freezing during the disc menu. I would hit play and nothing the movie just stayed and did nothing. I hit the disc menu button again and WOOP their it is the movie started playing without any problems. Little weird none of my other blu rays have this problem.
post #150 of 1308
Anybody have problems playing Sunrise Earth HD DVD. Seems to have problems loading, but when I load Planet Earth HD DVD then load Sunrise Earth it plays fine.
  Back to Forum: Dual Format Players
