Originally Posted by stephennothanks
Hello all. I just upgraded from a 26 inch westinghouse LCD to a new 52 inch samsung 650 LCD. On my old westinghouse LCD, the aspect ratio would automatically switch from 4:3 with black bars on the sides when viewing standard defn TV (I prefer this over any fill or stretch to avoid distorting the image on 4:3 images) to 16:9 when viewing a high defn 16:9 feed from a high defn channel.
With the new samsung, I seem to be stuck with one or the other. I can either set the TV to 4:3 which works well for SD/4:3 stations but shrinks the 16:9 channels, or choose 16:9 which looks good on high defn channels, but causes stretch and distortion on the 4:3 channels. It sure seems like this new samsung should be able to autosense/autoswitch like my westinghouse does. Am I missing a setting or option? Please tell me there is a way to fix this.
In case it matters, I'm using ATT U-verse with the Motorrola VIP 1200 set top box/DVR and have it connected to an onkyo receiver via HDMI, then to TV from the receive again with HDMI. The motorrola forces you to pick one output resolution, so I've chosen 1080i. But I don't think the set top box is the problem because I can connect it to my westinghouse and the westinghouse TV autosenses/switches aspect ratios with the same settings.
Thanks for any help you can offer.
Stephen
Stephen
I do know that with my cable box, a Scientific Atlanta Explorer 8240HDC DVR, that with it set to output at 1080i fixed resolution with the TV Type set to Widescreen.. the TV sees the input (connected via component cables) as 1920x1080i@60Hz and the SD channels are in their proper 4:3 aspect with left/right bars and HD channels fill the screen as they should when HD content is on. In my case, the cable box is actually adding the black bars to the signal because the input is always coming into the TV at 1920x1080i, regardless of the channel. Now, if I set the video type to passthru, then the SD channels don't display a particular resolution and fill the entire screen with no black bars.
So, it might be a setting on your cable box. Make sure the TV Type is Widescreen and not 4:3 something.
i'm not noticing any motion blur with it off so i'm just keeping it off. as an example, if anyone has invincible with whalberg, ply the scene where they are playing football in the lot at the beginning. made my head spin with it on high.
