Originally Posted by elmerfudII
I am about to pull the trigger on buying a LN52A650, but I've got a few nagging thoughts keeping me from completing the transaction. I'd appreciate some advice/input on the following.
a) should I really be buying an LCD versus a plasma ?
The plasmas have a little better picture, right ? If I didn't buy the '650, I'd get a Pany 50PZ800. I'm liking the '650 because its a touch bigger, the picture quality is supposed to be great, it has more features, including the net hookup stuff and I like the bezel better. I also like the fact it doesn't suffer from burn in like the plasmas do.
Does anyone have buyers remorse over buying an LCD instead of a plasma ?
b) Should I buy the '750 instead of the '650 ? I am going to be setting up a mythtv server for the AV system in my house. It looks to me like the '750 kind of supports DLNA, which the mythtv server supports. However, I could spend the money I save with the '650 on a dedicated HTPC, which could do way more than the '750 does and I could update it as things change in the future.
c) Should I wait for the LED backlit LCDs to appear ?
LED backlit LCD's are already here. Look at the 950 model.
), where do you think I should go to buy the cables at the most reasonable place, cost-wise (maintaining quality, of course).
