AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung LNxxA650 Owner's Thread
Official Samsung LNxxA650 Owner's Thread - Page 232
post #6931 of 23474
Originally Posted by sharkcohen View Post
I must say that my 650 does have a purple haze to it, although it is hardly noticeable and I can't see it when viewing content, i.e. it is not giving me any picture color quality problems or purple blacks. It was more pronounced with the backlight up at full with no powersave. It certainly doesn't look as bad as the couple of pics that have been posted in this thread.
I do wonder if the haze (purple over black) is largely attributable to strong backlight settings. The many reports and my observations in 2 stores (1 BB and 1 CC) confirmed the purple off-axis, yet one 46-incher in another more dimly lit BB showed little to none! God knows the backlight brightness is on full crank at most stores.
I have a 40-incher due Friday from the BigR Ranch. My typical view is a bit off angle (say, 25 degrees or so) due to the nature of the room; I am a bit concerned.
I am not really hearing any majority of our users complaining about the off-axis purple, but I don't know if that is because backlights are being set to more normal settings, users not typically viewing off-angle, OR simple inconsistency of manufacture.
Further observations? Comments?
post #6932 of 23474
From whom are you guys getting your extended warranties from (if any)? What are the good companies offering a good deal? Its too bad that monoprice doesnt sell those
post #6933 of 23474
Thanks a lot Dayton and jazzbass, I will try setting in the cable box.
post #6934 of 23474
hi all,
I was wondering if anyone has wall mounted a ln52a650 yet. does anyone have any wall mount suggestions?
post #6935 of 23474
Originally Posted by nitt4ever View Post
purple tint was never specifically a 46" problem.
Some people see it on any of the 650s, others don't. I do not see it on my 46".
Yeah I notice it on fade-to-blacks and in black bars at night on my 40", especially at 20-30 degrees off-angle or more. A bummer, but not a killer for me. LCDs just aren't great off-axis. Can't compare, because my old TV was much worse in every way, and never had a xx61 or xx71 in my room.
post #6936 of 23474
Originally Posted by 2wheels4me View Post
I do wonder if the haze (purple over black) is largely attributable to strong backlight settings. The many reports and my observations in 2 stores (1 BB and 1 CC) confirmed the purple off-axis, yet one 46-incher in another more dimly lit BB showed little to none! God knows the backlight brightness is on full crank at most stores. ... Further observations? Comments?
Well, I can see it is MUCH more noticeable with high backlight settings, which is one reason I use low ones (like 3 or 4). I started with Znutz's settings, but went one or 2 notches lower on the backlight (and compensated by raising the brightness) to tone down the purple haze in the black bars, particularly at night.
post #6937 of 23474
So my latest issue is audio/video timing problems.
With my last LCD I never had an issue with this: I send audio out of my DVD player as digital, run it through an outboard DAC, and then send the analog audio to my preamp. This gives me the best quality audio with my components, and it sounds great. One problem--the video goes out over component to the TV, and it seems that with this setup, the audio is slightly AHEAD of the TV video which makes it look like every movie is a poor lip-synch job.
Anyone have a suggestion how to delay the audio in synch with the video, or speed up the video? Could this have anything to do with video LAG noticed by the gamers out there? For movies I have AMP off (though for some reason it won't let me turn film mode on; I wonder if this has to do with component cable source). This TV sure likes greying out a lot of options.
post #6938 of 23474
I just want to chime in as well that if you buy from Big River and you call CEVA when it's in the warehouse, you can get it MUCH quicker. I called yesterday and mine was supposed to be delivered on the 9th, but instead, they are going to do it today.
Can't beat that.
post #6939 of 23474
This set does such a great job with PQ...even on SD channels/feeds. My question is, if I am using a STB that can output in all formats (480i, 480p, 720p, 1080i), what is the best choice for overall highest quality PQ? Is it to pass the signal to the tv as it comes from the STB (passthrough) or would it be to upconvert all signals, even SD channels, to 1080i? Would that sharpen the lower quality 480i signal or make it looks so stretched or unnatural that it would not be worth it?
Sorry...I haven't played much with these different formats. My wife prefers to watch some shows on SD channels in my area, and they are coming through at 480i and it just doesn't look "right".
Thanks for any help...
C
post #6940 of 23474
I just want to say that I had a 650 and returned it for a 750, the 650 had no purple tint during the two weeks I had it. The 750 however, has purple tint. I've had the 750 for less than a week. I looked for purple on the 650 and could not see it. The purple is easily seen on the 750 that I have.
post #6941 of 23474
Wow, not good. What feature(s) drew you to the 750 over the 650?
post #6942 of 23474
where do you guys see the purple? i need to know what to look for when they send me a replacement set for my defective 46a650. Also, what other defects/issues should i look for and how should i test for them? I will keep sending tvs back until samsung gets it right. Eventually they will lose so much money getting back second-hand tvs that they will be forced to give me a working tv.
post #6943 of 23474
I'm sure they are not sending you defective tv's on purpose. Why not just get the tv, and try not to "look" for problems. Just watch it and enjoy it. Maybe you'll be surprised.
post #6944 of 23474
Originally Posted by gnychis View Post
hi all,
I used this one:
http://www.sanus.com/us/en/products/...layout/layout/
It was only $50 at Costco and it worked great. It came will all hardware necessary to mount my 52. I did use the spacers included because I didn't want the mount to scratch up the back panel.
post #6945 of 23474
I have to say, I'm will be going to the movies a lot, lot, less because to this tv..
But. I seems to have signal issues with the xbox 360 using component set to display at 1080p.. I was playing devil may cry demo and the signal will go in and out.. Strange so far this is the only game that I'm having issues with.. Will have to play with the tv more..
post #6946 of 23474
DLNA and the different bezel. :/
post #6947 of 23474
Originally Posted by Edward98 View Post
I used this one:
I thought I read an earlier posting that made a comment about having difficulty with all the wiring, etc with the low profile mount. Did you have any problems with this? How do you have your wires run (including your power cord)? Do you have a surge protector? Any chance of posting some photos of your setup (wiring in particular)? Thanks.
post #6948 of 23474
There are previous postings of others having issues with the 360 displaying 1080P via component. I am not sure if someone resolved it, you might want to do a search on this forum.
post #6949 of 23474
I used this one:
a similar one at monoprice costs much less. it seems there are more poeple buying silver one than black one.
why is that? I thought black wall mount is better since it matches with TV color?
post #6950 of 23474
setting the 360 to output at 1080i fixed the issues.. Can't tell the difference between 1080p vs 1080i..
Another thing with this tv (52 inc), due to its size, you see how horrible directv image quality really is. Bluray is beautiful as is upscaled dvd's (HTPC using ffdshow).
post #6951 of 23474
which one is a better wall mount for 52a650:
This low profile one: has 1.25" gap between wall and TV. this makes it look nice but tight wall wiring.
or
This Adjustable Tilting Wall Mount Bracket : has 4" gap between wall and TV. big gap does not look nice but good for wiring.
Also Silver vs Black? which one matches better with 650?
post #6952 of 23474
I am new here to the forum and am in the market for a 52 inch screen. What is the opinion of the Sony XBR Bravia screens versus the Samsung LNxxx550 650, or 750 screens. I know Samsung is much less expensive.
Also I understand that new models seem to hit the market around July. Are there any new models worth waiting for?
Thanks for any information.
post #6953 of 23474
Advice Needed:
I'm a LN52A650 Owner and want to hook it up to my Media PC to watch 720/1080p files off my hard drive. It's a powerfull PC (4GB, quad-core, etc..) however I need to purchase a new video card. The PC also has a blu-ray drive, so I would use it as my blu-ray player also. Ideally, i wouldn't be PC gaming on it as I already own a XBOX360 - but having the option is nice.
I'm trying to figure out the best video card option for me. I would really like to use a high end card with HDMI out - so are there any recommendations?
I've been looking at the following cards:
SAPPHIRE 100221SR Radeon HD 3870 X2 1GB (512MB x 2)
GECUBE HD3870X2-F3 Radeon HD 3870 X2 1GB 512-bit (256-bit x 2)
BFG Tech BFGE98512GTXOCXE GeForce 9800 GTX 512MB 256-bit
One spec i'm not sure on as far as the benefits of HDMI output is the Stream Processors.
It appears the ATI cards have the NVidia cards quite beat in this area but i'm wondering if it matters for my purposes. I'm traditionally an nVidia fan but am open to whichever choice is best for this application.
post #6954 of 23474
Hmm. I suppose I could post some pics to see if it's what everyone else is talking about. I'd say it's bluish purple like this, and in no particular location (uniform screen, I see no clouds). I have yet to figure out how to get a reliable black screen--when I switch to a not-in-use source, it displays the source name and a periodically moving white box saying "No Signal" which is not great for a blank screen shot, LOL. I wonder from the talk on this thread whether some people are just more sensitive to it than others, or whether some sets really have NO purple haze. If some sets really have none, I suppose I should try to exchange mine, but with no clouds or dead pixels, I'm not sure I wanna risk it.
post #6955 of 23474
Hi guys, I have the 52" 650, my PS3 is hooked up via HDMI. Which output settings should I have activated on my PS3 for gaming/DVD/and Blu-Ray.
Giles
post #6956 of 23474
here it' s problematic
from a 46"
post #6957 of 23474
I have noticed that during basketball games I see light shade of either yellow or purple on the basketball court? This is not a permanent flash of light because when I switch to other programs the picture is flawless.....
Does anybody know why this happens. I am think it is a reflection of lights of the arean the games are played at.
Also....what is the difference between 1003.g and 1003.m? Which one is better?
Last but not least.......once in a while during a TNT Sport broadcast......their is a big green block the covers half the screen for a second. Is this TNT's fault or is this a defect from TV.
During other programs.in certain scenes their is very small purple coloring that appears on clothing......but it is nothing permanent........it just appears every once in a while.
I don't mean to be negative........this TV is awesome...........I watched INTO the blue last night on TNT and it was awesome.
P.S. The purple I am referring to is small flash......nothing near the picture that Sega Team posted.
post #6958 of 23474
Originally Posted by SEGA team View Post
here it' s problematic from a 46"
Thanks for reminding me SEGA. No, my 40" is not nearly that bad, and somewhat more of a bluish tint than your post. I suppose it's not worth considering an exchange. I'm looking to move to HDMI for movies, and then be able to use HDMI black level control to further reduce this appearance. I'll post pics later. Do you have a good idea for a blank screen, or do you think credits are best because they show roughly that you are using reasonable settings?
BTW, I won't bother with anything more off-angle than 135º since that's in my mind an unreasonable demand of an LCD.
post #6959 of 23474
just photos in normal conditions, with much blacks
post #6960 of 23474
If you want to test your settings for black crush fire up The Orphanage Blu-ray. Great detail in the shadows, they scale pretty well before going black if at all. It's a good black level calibration reference disc. I have HDMI Black Level on Normal, Energy Saving on Low, tweaked Standard Mode, Back Light on 7, and Black Level Adjust / Dynamic Contrast on Medium and The Orphange looked fantastic.
