Originally Posted by
frank70
1) The aforementioned zoom issue is a little more complicated than previously stated. If "zoom" is selected on an HD subchannel, it does the right thing. If "zoom" is selected on an SD subchannel, it either: a) has no effect at all if the SD mode is 528x480i or 640x480i (which is the desired effect and would be wonderful if not for b), or b) stretches the picture horizontally (off the screen at the ends) but not vertically (a purely nonsensical effect) if the SD mode is 704x480i; SD subchannels in 704x480i seem to far outnumber the others, but here in Philly there are some of both (for example 10.2, WCAU's weather channel, is unmodified by "zoom", as are all the WPPX/ION 61.*).
Not nonsensical, actually. The weird stretched mode is probably anamorphic. It is intended for a 16:9 picture transmitted shrunk horizontally which is how some widescreen stuff works, including in standard def.
frank70
2) On my unit, at least, the NTSC video output leans toward the left at the upper right hand side. Normally, you wouldn't notice this on an SD channel, or on an HD channel showing widescreen content. But on an HD channel showing 4:3 content (or on telecasts with some vertical object or a vertical edge on the right side of the screen) the lean very obvious, as it is when displaying the menu; it's as if the upper NTSC scan lines are shorter and more compressed than the lower ones - some kind of analog distortion. No, it's not my set... I've tried it on several. May be a sample defect, or may be intrinsic to the design.
That sounds like a classic TV problem. Top lines leaning have to do with the phase or frequency of the horizontal oscillator or sync separator issues. If the top left corner is ok but the top right corner is wrong, your horizontal oscillator probably isn't adjusting fast enough to the 180 degree phase shift in horizontal scan caused by interlacing. If you don't see it on other boxes, it may be because they underscan. Or your sync separator is sensitive to very subtle differences between the Tivax sync signal vs. others.
There is one other possible quirk in the Tivax. The schematic looks like there are two alternate amplifiers driving the video out U6 (FMS6143) and Q7 (2N3906). Neither is listed as do not populate so if both are actually populated pulling Q7 would be a good idea. There is also a 220uF capacitor (EC35) in series with the video out line. It is possible that the charge on that capacitor is reduced during the vertical blanking interval affecting the DC offset slightly. Your sync separator should be smart enough to adjust for the DC offset, which should be but some drift could be exciting the bugs in your TV.
frank70
3) One OTA channel in the NJ/Philly area scans in with the wrong subchannel number (WMCN-DT, which PSIPs as 44.1 on any normal DTV, comes up as 44.3 on the Tivax, with no 44.1 or 44.2 at all.) Fortunately, this station shows automobile advertisements all day long, and is virtually worthless anyway.
Maybe the Tivax is looking at the position in the PSIP terrestrial virtual channel table (TVCT) rather than the minor_channel_number stored there and the TV station is formatting the table in an unusual fashion or transmitting some audio only channels.
You may see this bug on other Zoran boxes not made by Shenzhen MTC since this sounds like it could be a bug in the reference software.
frank70
4) After a power failure, the unit DOES remember what channel it was last tuned to. BUT, if it was in the "standby" state prior to the power failure, it comes up in "on" state after power is restored. That is, it can remember the last channel, but not whether it was on or off!
The chip naturally powers on when it gets power. Then it reads the eeprom with the settings. It would then have to intentionally power itself off. Auto power up is actually something which should be configurable: on, off, or last state, but rarely is. Not powering up is probably worse than not powering up since if you have set the autooff timer it will power itself down in 4 hours and if you have disabled autooff you probably want the unit on for something like VCR recording. Thus, in the long run it is following your instructions.
frank70
5) The "standby" and "mute" buttons on the remote are positionally reversed compared to virtually every other (i.e. Japanese) remote. Power is almost always the upper right button on a remote, and if colored, almost always (for whatever reason) green; on the Tivax green-top-right is mute. Bizarre.
Not bizarre at all. I am surprised your remotes are that consistent. There aren't really any documented conventions for this. The Tivax is not a japanese box. I just looked at half a dozen remotes. Many had the power in the upper right, one had the upper left, a universal remote had the power button in the middle below the device buttons, and a TiVo remote had a TV power button in the upper left and the TiVo power in the upper middle. Colors varied.
frank70
6) The overscan in all aspect ratios is excessive, chopping off useful portions of program material, like the tops of heads and scrolling news at the bottom of 4:3 and zoomed 16:9 pictures- much more so than any typical NTSC tuner.
This is something that should be configurable. Absent that, you would expect them to stuff 480 lines of picture data into 480 scan lines.
frank70
7) This unit's tolerance of varying multipath (i.e. trees blowing in the wind) is rather mediocre. I think a lot of folks who buy CECBs are going to be pulling their hair out because of this issue, which is by far the most significant problem with ATSC reception in the suburbs.
So like most Chinese stuff, decently manufactured but poorly engineered and/or tested. My $.02.
[/quote]
Assuming the variation in multipath was consistent when you tested the different converters, the multipath tolerance would be a function of the Zoran SoC/demodulator chip. Finding good chips when you are designing something is very hard. In some markets, such as this, it is even worse because you can't download a real datasheet. The LG chip may be better but LG still doesn't even have a web page for their chips on their miserable web site.
Receiver performance in different locations is going to depend on 1) weak signal sensitivity, 2) static multipath rejection, 3) dynamic multipath rejection, and 4) adjacent channel rejection, 5) strong signal desensitization, 6) noise burst rejection, and 7) co-channel rejection.
NTIA criteria for multipath were for static single echo only.
Where I live, there are lots of big trees.
