For $1 it really doesn't matter. Where I live I couldn't get analog signals reliably anyway. And now there isn't much analog to speak of. So for me purchasing the T9 made perfect sense.
You might try Sears to see if they have any Zenith units in stock but, as you wrote wrt Kmart, I fear they are all but OOS everywhere on CECBs. However going with the Tivax instead would be very reasonable. PQ is very good, better than the Zenith, and tuner sensitivity is fine too. My only quibbles with it are:
- the remote, while quite nice, is somewhat directional. I have to concentrate too hard in pointing it from the right spot for it to work. Nonetheless it is very usable.
- doing a number of operations is a bit slow compared to the Zenith, most notably in changing channels and doing a channel scan. Just a little annoying.
_Lazza
_Lazza
