AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Tivax STB-T9 EPG
Tivax STB-T9 EPG - Page 4
post #91 of 274
Very useful! This is what I was hoping someone could do (haven't ordered my Tivax yet).
If you would be so kind, open up the serial connection before turning the unit on, and see if you get any kind of data as you power the unit up - maybe it outputs its boot process to the serial connection (I knew an ATSC tuner that did).
post #92 of 274
OMG!
From Config-1.txt:
option SUPPORT_DTT768XX_AFT 0
option SUPPORT_POWER_SAVE_MODE 0
option SUPPORT_740_LOW_POWER 0
option SUPPORT_EAS 1
option SUPPORT_QAM 1
option SUPPORT_CHMAP_ANALOG_DIGITAL_INTERLEAVE 1
option SUPPORT_NEW_CHANNELSCAN 1
option SHOW_VIRTUALCHANNEL_COUNT 1
override SUPPORT_BDF_FONT 0
override SUPPORT_ZTF_FONT 1
override SUPPORT_QAM 0
override ZTVAPP_CONV_BOX 1
override FORCE_AC3_RAM_MIXED_CODE 1
override SUPPORT_DIRECTPES_AUDIO 0
override SUPPORT_ANALOG_AUDIO 0
post #93 of 274
Here's the log from the boot sequence.
Tivax STB-T9 Boot.txt 4.0029296875k . file
post #94 of 274
Thanks - I'll dig on them what I can, and hopefully get my own box here soon too.
post #95 of 274
whitepelican, excellent work! If it can be figured out how to hack this box, then it elevates it to the top of my list.
post #96 of 274
I realize cross-posting is frowned upon, but should this also be listed in the "Hacking the CECB's" thread?
post #97 of 274
It is definitely C code. I couldn't tell what OS is running. It is linking libpng which is open sourced.
post #98 of 274
SupraHD ZR39740 Rev Unknown.
ZORAN SUPRA-HD Software
post #99 of 274
ThreadX
post #100 of 274
So we can see that the remote probably used NEC codes, from this:
override SUPPORT_NEC_REMOTE 1
whitepelican, here is a wild guess, but try typing in this:
set override SUPPORT_NEC_REMOTE 0
or maybe:
set SUPPORT_NEC_REMOTE 0
or maybe:
option SUPPORT_NEC_REMOTE 0
you can always enter:
help set
to see if it tell you any more. If successful, you can do another config and see if the value changes.
Of course, it is up to you if you want to try this or not, and this is just a guess. This *seems* like it would be harmless. If it works, you can set it back to 1.
post #101 of 274
My terminal settings were: Baud - 115200, Data bits - 8, Parity - none, Stop bits - 1.
This got me through to a "Zmon" prompt.
What was the Flow control set to? Xon/Xoff, Hardware, or None
I am assuming that HyperTerminal with Windows will work too.
You mentioned bash prompt so does this mean you were using Linux or hoping that the Tivax had bash.
What is it running I have seen both Linux and WindowsCE
option TL_LINUX 0
option TL_WINCE 0
I don't know if the prompt has different user modes like a Cisco Router.
User Mode >config
Privileged Mode #config
But looking at the boot log it may be setting things under this user mode
option SUPPORT_MACROVISION 1 (Turn on Macrovision)
option SUPPORT_VGA_MENU 0 (Turn off VGA Menu)
option SUPPORT_QAM 1 (Turn on QAM)
Look HOLL-ANDS it does have PASSTHRU but not enabled in the menu.
option SUPPORT_INTERNAL_RF_OUT 0
option SUPPORT_RF_OUT_MENU 0
Tivax should release a firmware update to customers/retailers so they don't loose sales to other passthru boxes.
I bet with the menu enabled it will turn these ones on if enabled.
option SUPPORT_NTSC 0
option SUPPORT_ANALOG_AUDIO 0
option SUPPORT_ANALOG_VIDEO 0
It does look like it is not capable of everything it lists
option SUPPORT_HDMI 0
option SUPPORT_INTERNAL_AUDIO 1
But when it is booting why change the default like this OFF:
option SUPPORT_AUX 0
To OFF again with an override
override SUPPORT_AUX 0
I can see the default being changed when it it not supported like:
override SUPPORT_INTERNAL_AUDIO 0
I wonder what other EPG it might be capable of showing
override SUPPORT_SINGLE_CHANNEL_EPG 1
So can you change anything over the terminal/serial connection?
I would try something that you can see changed such as
However, I don't know if this one has to be set also as it gets loaded first
If you can change does the setting get saved or is it only loaded until the box looses power.
It does look like it is loading configuration files during boot.
I wonder if you would have to modify these files to make changes.
post #102 of 274
I only mentioned bash because I was (probably mistakenly) thinking there was a *nix based system running in there somewhere.
Edit: Flow control is set to XON/XOFF
post #103 of 274
the QAM part is of notice to me. Have you tried altering it and running a scan with cable hooked up? This is a welcome find for the text files you have posted. Many thanks.
post #104 of 274
Waiting for my Tivax boxes to arrive - following was found in searching zoran.com
"The SupraHD family of highly integrated high definition digital TV processors are single IC HDTV solutions intended to meet the requirements for Digital Television receivers and unidirectional Integrated Digital Cable Ready markets."
and
"Zoran Demonstrates Latest Set-Top Box and Digital Television Technologies for Manufacturers at CCBN 2008 in Beijing
Processors Power Digital TVs, Set-Top and Converter Boxes Shipping to Global Markets
Sunnyvale, Calif. - March 19, 2008 - Zoran Corporation (Nasdaq: ZRAN) is demonstrating its newest digital television, set-top and converter box processors for consumer electronics manufacturers in Hall 1B, Booth B164 at the China Cable Broadcasting Network (CCBN) 2008 conference from March 21 to 23 in Beijing.
Zoran's SupraHD® 760, 770, and 780 processors power digital television products under brands such as Daewoo, Dell, Hitachi, Best Buy's Insignia, Orion, Proscan, RCA, Sanyo, Sharp, Sceptre, Toshiba and others.
Zoran's SupraHD® 741 processors power NTIA- certified ATSC converter boxes for the U.S. broadcast transition including models from AMTC, AccessHD, Apex Digital, MicroGem, RCA, Tivax, and others."
a search for "linux" on the zoran site shows they are looking for people with linux/unix experience. hope this helps.
post #105 of 274
sorry, newbie can't post links here but here is more info:
"SupraHD 741
ATSC Converter Box
SupraHD® 741 reference design consists of a set-top-box ready for manufacturing and a set-top-box application with complete middleware software stack, including closed-caption support. The set-top-box accepts all the ATSC formats (480i, 480p, 720p, 1080i) and outputs 480i to a NTSC TV.
* Overview
* Features
* Diagrams
Overview
The SupraHD® 741 Processor is highly integrated, consisting of an 8VSB demodulator, an MPEG-2 HD decoder, high-performance CPU, graphics engine, video scaler, channel 3 / 4 modulator, stereo audio DAC and integrated sleep mode support without a microcontroller. It also supports a variety of system interfaces, such as an infrared receiver, flash memory and DDR SDRAM interfaces. The decoded ATSC video stream can be output in composite (CVBS), and S-video (Y/C, optional) and channel 3 / 4 RF modulated formats.
Audio can be output in analog format (L/R). Designed to use the minimum external components, the SupraHD® 741 Processor requires only memory, ATSC tuner, power supply, and a small number of passive components to build a complete ATSC converter box.
SupraHD 741 NTIA Compliance Summary
NTIA Item # NTIA ATSC Converter Box (DTA) Requirements SupraHD® 741 Converter Box Compliance
1 Decoder ✔
2 Output Formats ✔
3 PSIP Processing ✔
4 Tuning Range ✔
5 RF Input ✔
6 RF Output ✔
7 Composite Output ✔
8 RF Dynamic Range ✔
9 Phase Noise ✔
10 ✔
11 First Adjacent Channel Rejection ✔
12 Taboo Channel Rejection ✔
13 Burst Noise ✔
14 Field Ensembles ✔
15 Single Static Echo ✔
16 Channel Display ✔
17 Close Captioning, EAS, Parental Control (V-Chip) ✔
18 Remote Control ✔ (Manufacturer to provide)
19 Audio Outputs ✔
20 Energy Standards ✔
21 Owner's Manual ✔ (Manufacturer to provide)
22 LED Indicator ✔
23 RF Cable ✔ (Manufacturer to provide)
24 Signal Quality Indicator ✔
Package Contents
* ATSC converter box reference design
* Power adapter, remote control, and necessary cables
* Pre-loaded ATSC software on flash memory
* Production proven Zoran ATSC middleware and fonts
* Complete documentation for reference design, software, and IC on a CD-ROM
Key Hardware Features
# SupraHD® 741 Processor
# SPI Flash Memory: 1MByte
# DDR SDRAM: 32MByte (16M x 16b)
# ATSC Tuner
# Video Out: 480i composite (CVBS), S-Video (Y/C, optional)
# Audio Out: L/R analog
# IR Remote, I2C
# Ch 3/4 RF out
# Smart antenna (optional)
System Software Features
# NTIA & Energy Star Compliant
# ATSC converter box application software
# PSIP parsing for channel map
# Digital Closed-Captioning (EIA-608)
# Transport, video decode (single MP@HL), audio decode (AC-3, MPEG Layer 1/2/3), graphics, and display drivers
# Peripheral drivers for tuner and demodulator
# Thread-X royalty-free operating system
SupraHD® 741 Block Diagram
SupraHD® 741 Block Diagram (PNG)
(PNG)
SupraHD® 741 System Architecture
SupraHD® 741 System Architecture (PNG)
SupraHD® 741 User Interface
SupraHD® 741 User Interface (PNG)"
post #106 of 274
from supra hd site:
# ATSC Tuner
# IR Remote, I2C
# Ch 3/4 RF out
# Thread-X royalty-free operating system"
post #107 of 274
post #108 of 274
Originally Posted by wisfarmer View Post
from supra hd site:
# ATSC Tuner
# IR Remote, I2C
# Ch 3/4 RF out
Does it mean that it does not support QAM?
post #109 of 274
Yes, since the 741 was specifically targeted for CECB, the specs do not include QAM.
I would be surprised if it can simply be turned "ON".
The SupraHD 770 and 780 include QAM...and a bunch of other stuff:
http://www.zoran.com/SupraHD-770
The earlier SupraHD 640/660/680 series used external Cascade2 (CAS-220) chips:
http://www.zoran.com/IMG/pdf/SupraHD_Family.pdf
http://www.zoran.com/Cascade2
post #110 of 274
holl_ands do you think that it does have PASSTHRU but not enabled in the menu?
post #111 of 274
or maybe:
or maybe:
help set
I can't seem to find a way to get any of these commands to work. Everything I try with "set" gives me "Syntax error: bad integer". If I try using just "option" or "override" both say there is no such command. I've tried every combination I can think of, but none of these commands are correct.
post #112 of 274
Try /Set /set or Set: or set: possibly.
You are using 0 and 1 for Off and On correct?
post #113 of 274
From your help all.
history ................................ history display up to 20 previous commands executed
set .............. set to set current val at particular index type set
tunerinfo ............................. tunerinfo show tuner settings
If you haven't tried to many things it would be interesting what history would show.
The tunerinfo command may also confirm if PassThur is supported.
Does it change modes when using config like Cisco?
Router#config
Router(config)#
post #114 of 274
It recognizes the command "set" just fine, I just can't seem to get the correct syntax. I've been using commands like "set SUPPORT_NEC_REMOTE 0". It always comes back with a syntax error.
I think "set" is not the command we're looking for to change those values.
Code:
ZMon>set SUPPORT_NEC_REMOTE 0
ZMon>option SUPPORT_NEC_REMOTE 0
Invalid command. Try "help"
ZMon>override SUPPORT_NEC_REMOTE 0
ZMon>set 0 SUPPORT_NEC_REMOTE
ZMon>set
 Try a index between 1 & 419
ZMon>help set
post #115 of 274
What does tunerinfo show?
Also what does history show?
Does the history get cleared when it looses power?
post #116 of 274
ZMon>tunerinfo
740 Firmware Version ID = 0b01,0107,0260,0010,0010,0000
ZMon>history
!1 set
Yes.
post #117 of 274
Could you post the output of symname, symaddr, and vars?
post #118 of 274
Code:
ZMon>symname
SUPPORT_ZSYMTAB is off
ZMon>symaddr
SUPPORT_STACKTRACE is off
See attachment for "vars".
vars.txt 7.0126953125k . file
post #119 of 274
*deleted* Never mind, I should have read all the text files first before posting a clueless ZMON suggestion
post #120 of 274
Thanks again to whitepelican for this breakthrough.
I think the syntax for the "set" command (set index value) may require "index" to be an actual number (from 1 thru 419, as you were told when you entered "set" with no arguments), so the question is: What range of memory or array (of length 419) does the index point into, and what does each index in that array affect?
Maybe the "view" command (with no arguments) will give a list of indexes (or indices, if you prefer) in the TL_controlarray (whatever that is), and MAYBE that's what you can set with the "set" command. (You could also try "view 1 0", "view 1 1", etc., through "view 419 1", the second argument being "useTabs" off/on -- see Help All.txt
By the way, the Zoran SoC is known to be used in several CECBs, as can be seen at en.wikipedia.org/wiki/Comparison_of_CECB_units
-Bob, a.k.a. rrrrrrobert
