AVS › AVS Forum › Audio › 2 Channel Audio › Need help, new to 2 channel...
post #1 of 7
Hi there,
I am currently in the market to put together a 2.1 system for the sole purpose of music. My music taste revolves more or less around trance, heavy on vocals and instrumental heavy trance.
My current system is a pre-boxed system, the Logitech Z5500's, information on the system can be found at the Logitech website, as I can't post URL's as I'm new
They are hooked up to my desktop, and do a sufficient job of reproducing music how I would like it, But, I am unhappy with the quality of the satellites, the music often gets drowned out by the sub.
I am very passionate about bass, but would like to move to something that sounds much clearer and crisper when it comes to the mids and highs.
With that in mind, I would like to pick up a receiver($250-$400 range), a pair of excellent sounding book shelves ($250-$750 price range) and a sub, which may come at a later time. I do not want to skimp out on a sub. For the sub I want the bass lines to be super smooth and accurate at all frequency's, as trance can throw a lot out there. I have music playing whenever I am at home, so it would be put to use.
Could anyone point me in the direction of where to start on this system? Even just a receiver + speakers for the time would be good. I leave a wide price range for the speakers, as I'm willing to spend more if needed, but would settle for something at a lesser price if it sounded how I wanted.
post #2 of 7
I'd start by looking in the yellow pages for local stores that sold hifi gear. Then I'd put together a sample CD that contains some of the music I like to listen to. Next I'd go to all local stores and start listening.
post #3 of 7
Originally Posted by _Hotsauce_ View Post
Hi there,
As dknighted says.....get out and listen !
Now two cents worth of advise on bass (sub)......if music is the 'sole' reason for this set-up , then what you want is a 2.0 system that utlizes a 'servo based sub' in conjunction with a good eq set-up. For ease of installation and good value I recomend the "DD" series of subs from Velodyne. You merely run another set of I/C's from a second output of receiver or pre-amp to the sub and bring "it" in with respect to bass roll-off of your main L/R speakers, utilizing the buit in eq programing to facilitate this.
I know I somewhat beleagured the 'bass' point, but you seemed passionete about the need !
Good Luck !
post #4 of 7
A good start would be to get an integrated amp from Cambridge Audio, Rotel, or NAD; the Pioneer Elite is the cheapest one available.
Speakers: Paradigm, PSB, & B&W are good brands to check out first.
post #5 of 7
"Now two cents worth of advise on bass (sub)......if music is the 'sole' reason for this set-up , then what you want is a 2.0 system that utlizes a 'servo based sub' in conjunction with a good eq set-up. For ease of installation and good value I recomend the "DD" series of subs from Velodyne. You merely run another set of I/C's from a second output of receiver or pre-amp to the sub and bring "it" in with respect to bass roll-off of your main L/R speakers, utilizing the buit in eq programing to facilitate this."
So that more or less went right over my head. Could you explain it in um....a non-stereo person kinda way? :P
post #6 of 7
I'd have a look at an integrated amplifier from NAD or Marantz, or a stereo receiver from H/K, Marantz or Onkyo. You gave a wide price range for speakers. I'd have a serious look at the Concerta M12s from Revel.
post #7 of 7
I listen to a lot of EDM, particularly vocal trance, but I do like hard trance, house, and progressive. My suggestion would be Paradigm Mini Monitors for bookshelves, a higher-end Yamaha receiver (RXV series)--although I would highly recommend going separates (like a Rotel RC-1070 preamp & the small RB series power amp; both can be had for $700-800). The reason I mention that is that the SQ is way better and you can add a different amp. Sometime in the future I would highly recommend picking up a tube amp...these things work magic with EDM. As for the sub, I think a Paradigm PDR-10 would be entry level...they sound nice and blend well, but not quite as tight as you might be looking for and could get out of a Velodyne or B&W. This is where you'll probably need to visit a few shops and listen to various models.
