AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Harmony and Pronto remotes?
post #1 of 8
I have a Harmony remote that currently does a decent job for the money. The only thing I don't like is the response time of the remote compared to the original remotes (laggy) I have played with all the settings but its not quite 100%. Im not too fussed about macro's/extra commands that I know the Pronto has over the Harmony. I guess my question is, does this just happen with the Harmony range of remotes and how they learn/transmit codes or would something like the Philips Pronto or any other brand have a better response transmitting IR commands then the Harmony? ...just wondering if a diff remote brand will fix the laggy remote commands
post #2 of 8
Did you see the sticky thread in this forum?
post #3 of 8
Yep have tried quite abit including the sticky thanks I've read reviews and from what I'v read the Harmony remotes tend to be like this abit in response time? I just wonder if its Harmony remotes or would get the same result with a Pronto remote?
post #4 of 8
I would say that my pronto's, harmony (the one made for xbox360, etc) , and original remotes all have the same response time on my stuff, which is mostly all Sony equipment. At least it's so close I can't really 'feel' any difference. I would think that by shrinking the various delay settings you could probably get the programmables faster than the original remotes but you may loose realiablity.
post #5 of 8
I haven't seen a single device where the Harmony remote was slower than the original remote. Can you post what devices you are having issues with and what settings you currently have?
post #6 of 8
When people say that their Harmony is slow they are not saying that a specific command to a single device is any slower then the original remote's command. Rather, the "issue" (if there is one) is in sending a sequence of commands generally to different devices seems to be slow.
post #7 of 8
I'll have to double check my settings but I have tried all different combos. What I mean is that when I use my original remote for a device eg. satelitte, AV receiver it works instantly as normal. With the Harmony there is either a slight delay/reponse not quite 100% compared to the original remote...
post #8 of 8
If you post your equipment and settings, other owners will be able to post what has worked for them.
  Back to Forum: Remote Control Area
