Originally Posted by
Ken H
Yes it is, comparatively to CBS & ABC. I don't know where you got your info from, but it is wrong.
I had this filed away, not sure where I got it from. It appears to be remote setups, but the post network operations center numbers look to be accurate.
(1) FOX takes its 1.0Gbps (uncompressed) 720p truck feed, compresses it down to 73Mbps or less for their operations center, and then uplinks it to satellite at 14.6Mbps for distribution to local affiliates.
FOX affiliates pass this feed through without any extra processing or compression using specialized equipment provided by FOX.
(2) CBS takes a 1.5Gbps (uncompressed) 1080i truck feed, compresses it down to 45Mbps for their operations center, and then uplinks it to satellite at 45Mbps for distribution to affiliates.
CBS affiliates process and re-compress this 45Mbps feed to 19.4Mbps or less. Some CBS affiliates have newer/better encoders than others.
(3) ABC takes a 1Gbps (uncompressed) 720p feed at the truck, compresses it down to 45Mbps for their operations center, and then uplinks it to satellite at 40Mbps for distribution to affiliates.
ABC affiliates process and re-compress this 40Mbps feed to 19.4Mbps or less. Some ABC affiliates have newer/better encoders than others.
(4) NBC takes a 1.5Gbps (uncompressed) 1080i feed at the truck, compresses it down to ~38Mbps for their operations center, which then recompresses and uplinks it to satellite at 24Mbps for distribution to affiliates.
NBC affiliates process and re-compress this 24Mbps feed to 19.4Mbps or less. Some NBC affiliates have newer/better encoders than others, and since NBC was the first network to launch with high-def, a number of affiliates are still using [outdated] early generation encoders.
The higher the quality of the source, the better the result with compression. Because NBC distributes its feeds at lower bitrates, more bandwidth is needed to produce a comparable picture to say, CBS. Unfortunately, they rarely get it and quality suffers as a result.
If I'm not mistaken, one of the reasons NBC uses a lower bitrate is because they use Ku band transmission whereas the others all go with C-band.
